Old 12-09-2013, 12:45 PM   #1
joel.e
joel.e's Avatar
Driveshaft clearance at trailing arm cross member
Does anyone know the drive shaft clearance for the various trailing arm crossmembers. Specifically I'm looking for the value from the top of the frame to the top of the hoop for the driveshaft. If I put a straight edge across the frame at the rear of the stock cross member and measure to the top of the drive shaft hoop, it comes in at about 3/4". Just curious if anyone had other measurements of Porterbuilt, ECE, CPP, etc. which are intended to be used with drops. My trans sits a little high in the back so I need the most clearance possible. Just didn't know if I could get away with buying one or having to modify the stock one.
1967 C10 SWB Fleetside Duramax/Allison
1966 Chevelle Malibu, EFI BBC, pro touring starter kit
joel.e is offline   Reply With Quote
Old 12-12-2013, 09:43 AM   #2
Robznob11
Robznob11's Avatar
Re: Driveshaft clearance at trailing arm cross member
You wont gain a whole lot of clerance maybe 1/2" the looks are deciving. The aftermarket members are straight across the top wich makes the loop look taller than it is. With that said they are alot stronger. I have the cpp. I wish i would have went ece. The ece has bolt on brackets so they can be flipped if you want to change anti squat. Cpp is welded in the flipped position so there is no choice. Also as much as i wanted to run the exhaust through the member the ovals were just not big enough for the 3" pipe. Ece are round
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 12-12-2013, 10:04 AM   #3
Pro Performance
Pro Performance's Avatar
The Porterbuilt cross member does give 3/4" more clearance for the driveshaft to come up.
Pro Performance is offline   Reply With Quote
Old 01-23-2018, 05:42 PM   #4
Styler1968
I'm having the same issue, are you 100% certain on that?
Styler1968 is offline   Reply With Quote
