Old 12-09-2013, 05:42 PM   #1
forestb
forestb's Avatar
cut coils
I have a 77 front end on my 62 and I used the original coils that I got with the front end only I have cut about 1.5 coils off of them. The front end also had coil springs around the shocks which I replaced for a set of cpp shocks that are the correct length for the amount of drop. The ride quality is horrible and I was wondering if it would be smoother if I installed a set of cpp 2.5 inch drop coils.
forestb is offline   Reply With Quote
Old 12-09-2013, 07:22 PM   #2
donthekawguy
donthekawguy's Avatar
Re: cut coils
Drop coils are always better than cut. They have a progressive spring rate and will get stiffer as they "squish". Heating springs is a big no and cutting them is almost as bad in my book. Spend the hundred and change for a better and safer ride. You can always go with drop spindles if it needs to be lower and the spindles will work with your shorter shocks.
66 shorty
donthekawguy is offline   Reply With Quote
Old 12-09-2013, 11:37 PM   #3
MisterC
MisterC's Avatar
Re: cut coils
I can't vouch for the CPP coils as I went with ECE coils. My previous coils had been heated and it rode like crap. I installed 2" drop coils and the appropriate shocks, along with an 1 1/4 sway bar and it was an amazing change. I can't say enough about how much better it is.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
