Old 12-09-2013, 06:34 PM   #1
MR6X6
MR6X6's Avatar
How can i put blazer bumper on my k30? ?
HELLO, ANY BODY KNOW WHAT WILL BE NEEDED TO DO TO INSTALL A BLAZER STYLE BUMPER OM MY 1987 K30 ?
MR6X6 is offline   Reply With Quote
Old 12-09-2013, 06:54 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: How can i put blazer bumper on my k30? ?
You will probably need to make or
modify brackets because the frames will be different
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 12-10-2013, 05:42 PM   #3
1774btcrew
1774btcrew's Avatar
You can use the outer blazer brackets. As far as the inners go you will have to modify the blazer ones or come up with some off of a pick up. I wish that I had made a template when I had the last set of 81-87 sport bumper brackets
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 12-10-2013, 06:48 PM   #4
MR6X6
MR6X6's Avatar
1774 4btcrew thanks my friend, chris
Old 12-10-2013, 09:05 PM   #5
nekkidhillbilly
bolts............had too
nekkidhillbilly is offline   Reply With Quote
Old 12-11-2013, 11:57 AM   #6
1774btcrew
1774btcrew's Avatar
No problem! Good luck!
Old 02-26-2014, 02:21 AM   #7
lightningtruck
I could swear all I did was take the bumper off my '88 and put on a blazer bumper. The step bumper may have different brackets. I just took a bumper off a '90 suburban. I have all brackets, bolts and center section for plate and light if you need it. On my '88 I put a gas door license plate bracket on and made the receiver hitch hide behind it. Good luck. They look great but you cannot step on those blazer bumpers!
Mike McGinnis
1990 V3500 Crew Cab build http://67-72chevytrucks.com/vboard/s...d.php?t=559196
1983 C10 Step Side Old Friend http://67-72chevytrucks.com/vboard/s...45#post7266145
lightningtruck is offline   Reply With Quote
