Old 12-09-2013, 06:58 PM   #1
Hogger54
Hogger54's Avatar
Fuel pump installation?? Is this right?
I can't find any definitive answer which way this should install. Some directions say arm up, like in the picture, and some say arm down.
Hogger54 is offline   Reply With Quote
Old 12-09-2013, 07:08 PM   #2
OrrieG
OrrieG's Avatar
Re: Fuel pump installation?? Is this right?
Looks like you have it right.
http://www.google.com/imgres?sa=X&bi...r:55,s:0,i:252
Make sure the cam in unloaded when installing to keep from breaking off the ears.
OrrieG is offline   Reply With Quote
Old 12-09-2013, 07:15 PM   #3
Hogger54
Hogger54's Avatar
Thank you.
Not entirely sure what you mean by unloading the cam. I have had to rotate the engine around to try and get the pump to sit against the block, but it just needs another 1/8" or so.
Old 12-09-2013, 07:47 PM   #4
OrrieG
OrrieG's Avatar
1/8" is not a big deal, you just do not want to be trying to compress the lever an inch using the mounting bolts. Just make sure you tighten them equally, couple turn on one, then the other. Also lube the heck out of the lever end with some white lithium grease. Locktite will keep the bolts from backing out causing oil leaks around the gasket.
Old 12-09-2013, 07:56 PM   #5
Hogger54
Hogger54's Avatar
Cool, thanks!
Old 01-24-2014, 06:27 PM   #6
Bnabb0618
What brand fuel pump are you using? I need to get one for my 235 and was just going to order the airtex pump, But I vaguely remember reading a post that they didn't work quite right.
1950 Chevy 3600 - Newest Project
1993 Jeep Wrangler YJ- Daily Driver
2001 Jeep Cherokee - Wife's Ride
Bnabb0618 is offline   Reply With Quote
Old 01-24-2014, 08:21 PM   #7
studda
studda's Avatar
Looks like the exact fuel pump I got from my local Federated Auto and, yes it's correct. I had to push mine in a little to get the screws started.
studda is offline   Reply With Quote
Old 01-24-2014, 10:47 PM   #8
Hogger54
Hogger54's Avatar
It is an Airtex. Part number 4149
Old 01-24-2014, 11:24 PM   #9
studda
studda's Avatar
Did yours come with a gasket? If not, definitely make one or buy one. Not trying to insult your mechanical skills; I'm just looking out for you.
Old 01-24-2014, 11:42 PM   #10
Hogger54
Hogger54's Avatar
Can't remember if it came with one or not, but I put one on. Just holding it there for the pic.
