Need help steering shaft repair
I am redoing my steering column and noticed that the rubber boot on the steering shaft [the rubber boot that holds grease in the slip joint] has failed and the slip joint is worn. I want to know if I should cut the shaft and replace the the slip joint with a 3/4 36 spline x 3/4 dd coupler or does a universal joint need to be installed. I will be drilling the shear pins out of the shaft so i will have a slip point. Any pics of modified shafts would be great. Thanks
1971 c 10 manual steering
Fuzzy |
#2 | |
The Older Generation
Re: Need help steering shaft repair
If I were you I would just find a good stock replacement one... LockDoc
ttt
Fuzzy |
Well some time has gone by and I have removed and body worked the shifter bowl to make it smooth and got the steering column stripped and painted and it is looking good. I did pick up a u joint that is a direct fit and looks good to. Next I sent the slip shaft with my buddy to mill it dd all the way so I can cut it to the proper length. Here is a few pics
Fuzzy |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looks nice, should work real nice
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Thanks Dale the old joint had lots of play and I did not like the grease running out of the boot on my fenderwells
Fuzzy |
If you replace the rag joint with a new one the steering should feel nice and tight. Some people replace the rag with a u joint as well but in my opinion that lets to much vibration to be felt at the steering wheel.
How do people hook up the second u joint instead of rag joint? Does it take out more play than a new rag joint?
Currently Blazerless
Here's what I use on my trucks, early to mid 90s Jeep Cherokee steering shafts, it's almost a bolt in. You will have to heat and collapse the shaft just a little and on the columns shaft you will need to grind or file a very small notch to clear the Jeeps pinch bolt. The Jeeps shaft has a built in vibration damper and I've found this setup really helps firm up the Chevys steering. Practically a bolt in for around 30 bucks from a salvage yard.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 05-11-2014 at 11:12 PM. |
Another
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
One more
Wow! Great information! Thanks!
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
#13 |
Does the universal joint slide all the way on column end until bottoms out or until flush with inside hole? Hopefully that makes sense. Lol
#14 |
Digging up an old bone but very appropriate to my question. Blazerman's photos give reference. Jeep splines are 3/4 -36? and the other is 3/4 DD? Like Borgeson unit but price is a bit steep.
Leadbelly |
#15 |
I believe to. I have an XJ shaft on my Blazer and C10. Around here, they are about $6 from the yards. Most of the time the rubber at the top is worn and sloppy, so I weld it. Amazon sells new shafts for $99 last I saw. They are on most square body Cherokees, not the Grand Cherokee. 80s- early 90s
I've probably used or sold 20 of them.
'68 C10 SWB '85 K30 Blazer |
#16 |
Just wanted to say thanks for the info. This is exactly what I was looking for. Best 10$ spent so far.
Posted via Mobile Device |
#17 |
![]() Join Date: Apr 2013
Does the Jeep steering shaft mod only work for manual steering boxes
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
#18 |
My guess, top yeah, double "D" and 3/4". As far as steering box do not know the spline count so no idea.
Leadbelly |
#19 |
I got the steering shaft but it does not work for a 72 4x4 with power steering. I thought this worked for all 67-72. If so wondering what I might be missing.
#20 |
How many splines on your power steering box?
1968 LWB C20 / AC / Wood Bed |
#21 |
32 splines
#22 |
From the info above, the jeep shaft looks to be 36 spline so I'm thinking it won't work.
#23 |
I found it quicker, much easier, and guaranteed to work going to CCP. I am switching to Borgsen just because I am not a fan of chrome polishing on the joints for my truck plan. Black are easily overlooked. Here is a link to my swap, from ordering parts bolting on new parts.
https://www.flickr.com/photos/dodson...57662779313234 Sorry do not know if or how to post build pics. Leadbelly |
