Old 12-10-2013, 12:15 AM   #1
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Any thoughts on adding a DRAC
The speedo on my crew cab has always been 4-5 MPH slow. (01 5.3 /4L60E). The tune was supposed to be set up for the tire size but? I am using a 91 cluster. I just went bigger on the rear tires and now the speedo is 10ish MPH slow. I wonder if adding a modified Drac would correct this.
As I understand it I would install the Drac in between the VSS and the PCM
And would have a separate out put for the speedo. I have seen the article about modding a drac for my input. The question is if the later 4l60 outputs 40 pulse per rev/4000 per mile. . Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 12-10-2013, 04:44 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Any thoughts on adding a DRAC
4L60e's are 40ppr, which IIRC is the same as what the 90-91 cluster uses. You need to go from ac-sine wave to DC square wave for the thing to work though.
Thing is, to recal the speedo, don't you have to change the teeth on the 8pin plug on the cluster? Cuz you'd have to get a new one of those, which matches what you need or hasn't been setup (destructable), and they don't make them anymore. *This is just from reading misc junk while looking at swaps*
I thought all the modified drac would do was let you have outputs for the ecm AND cluster etc, not to actually change the function on the cluster? I may be confused on this, as the information seems to change heavily from 89-95 in terms of HOW it needs to happen.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-10-2013, 09:54 AM   #3
Big Port Jimmy 6
Addicted to Rust
Let me clarify I have a R body cluster (square body) not the 91 CK cluster so I don't think they calibrate that way, but I will check my spare. You can modify a drac for different in put value that you calc with your tire info. Jay
Current trucks:
Old 12-10-2013, 11:44 AM   #4
ls1nova71
ls1nova71's Avatar
The '91 cluster should work perfect right out of the box. You say "The tune was supposed to be set up for the tire size but?" makes me think it's just not set right. If you have the tuning software it should be relatively easy to get right.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-10-2013, 04:07 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
hence, I'm lost.
Old 12-10-2013, 08:57 PM   #6
Big Port Jimmy 6
Addicted to Rust
I feel like the tune is right, but that the speedo is inaccurate. a problem that I exacerbated with changing the rear tire size I did not do my own tune and do not want the equipment as a means to keep me from screwing with it all the time. And really do not want spend a lot to redo the tune
Brew City the 1/2 tons in 88-92ish are the new body style the 3/4, tons Burbs and Blazers are like the 81-87 trucks. Some of them have electric speedo clusters, which is what I have. Jay
Current trucks:
Old 12-11-2013, 02:01 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
oooooh its like the whole "silverado Classic" thing on the NBS trucks....gotcha.
