Old 12-10-2013, 07:56 PM   #1
cleszkie
cleszkie's Avatar
Another Harmonic Balancer Question
Is it common for the outter ring on a balancer to slip out of adjustment? I have never been able to get my base timing down to 10 to 12 degrees. It has always read up in the 20s with vacuum and mechanical advances disabled. Engine runs and idles fine with good power and fuel consumption, but it has always bugged me.
cleszkie is offline   Reply With Quote
Old 12-10-2013, 08:45 PM   #2
mmiddle
mmiddle's Avatar
Re: Another Harmonic Balancer Question
Very... not un-common with age and oil soak. I've seen quite a few. Like any rubber based product it will rot and shrink with age and swell when soak with oil.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 12-10-2013, 08:52 PM   #3
cdowns
cdowns's Avatar
or you could also have the wrong timing ponter installed
Old 12-10-2013, 08:58 PM   #4
Longhorn 70
Longhorn 70's Avatar
It also can throw the outer ring under race conditions. Like when the F##d doesn't know your Longhorn has a built BB Olds under the hood and tries to show off.
It was running a little rough and thought it was losing timing. Hooked up a timing light and shined it down. I then noticed the ring was gone.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
