67-72 Factory Tach Dash
Original factory tach dash I have been hoarding for a few years . It is in original condition. The truck it came from was not running and I have not checked the tach for function. It will probably need a new circuit board as I cans see some wear in different areas. The speedometer and odometer both work. The other gauges are un tested. The numbers on the gauge faces look nice but the needles will need to be repainted. Tinwork good, bezel good for a driver only as it has a few cracks here and there. This is an 8 cylinder tach. I can also see some writing on the back of the tach . Repaired in 91 and the techs name. $250 plus $20 shipping . If shipping is less I will refund the difference. If more I will take care of it. This applies to the 48 states. USPS M.O.
Reason: Gauges untested
