Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-11-2013, 01:23 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wink Adding more
OK worked on the radio some more this week. I made a plate to hold the 2 dash speakers in place instead of them just sitting on the top of the radio. I cut 5" strips out of the plate and drilled a hole on each end. One end mounted to the center AC vent stud the other I used small machine screws to attach it to the speaker plate.
I'm also going to start on the cab corner mounts I bought from member bigblock73.
What size speakers U think I sould use in the corners. I got them without any holes so I can cut them for any size, the picture is from bigblock73 to show how they look. They want be hooked to the amps just off the radio.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
