12-11-2013, 03:49 PM | #1 |
bucket seat advice
Since i will be doing a cab swap i have thought about going with bucket seats. What should i look for to make it a painless swap. What seats fit the best
12-11-2013, 04:10 PM | #2 |
Re: bucket seat advice
Going down the list, I would rate squarebody pickup seats first, second would be Suburban, third would be Blazer, and forth everything else. Suburban seats only need the back tabs bent up. Also you need the front inside brackets.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
12-11-2013, 04:15 PM | #3 |
Easiest fit would be the Squarebody pickup bucket seats, as they are a direct bolt in. Good luck finding these, very rare option.
Next is Suburban bucket seats, the rear tabs need to be bent up to be a bolt in. Blazer seats are the same, however the mounting base is different and would need to be swapped to pickup/Suburban tracks. I would stay away from these for a pickup swap. And of course there are many other bucket seats out there from various other cars and trucks. This of course would require fab work and typically aren't a bolt in solution. |
12-11-2013, 04:47 PM | #4 |
What year suburbans? Didn't even know squarebodies came with buckets
12-11-2013, 04:54 PM | #5 |
any year suburban that the option they had them for the duration if im not mistaken. seems like the the 3 doors in the 60s had a bucket seat option. the later 80s ones look the best. i thought about buying a set for crew cab project when it gets going and using a middle jumpseat console with them but i leaning toward a aftermarket seat now.
12-11-2013, 06:47 PM | #6 |
MusicMan70 1961 GMC Suburban |
12-11-2013, 08:08 PM | #7 |
They are more like captain chairs than buckets really.
Anyways these are my favorite style Suburban seats, out of a 88-91 Sub. These are the seats in my C10 |
12-11-2013, 09:44 PM | #8 |
Is that the console for the burb seats as well?
12-11-2013, 10:39 PM | #9 |
Yes I pulled the console from the Suburban as well. Make sure you get all brackets and even the seat belt buckles.
12-12-2013, 08:58 AM | #10 |
If your pulling buckets from a suburban, make sure you grab the inner brackets that are welded to the floor, it may take a couple of minutes to cut them out with a sawzall but it will save lots of time spent fabbing up custom brackets.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
12-12-2013, 04:03 PM | #11 |
85 Suburban buckets..Love em.
12-12-2013, 05:47 PM | #12 |
78K & 79C Jimmys
I used 89 burb in my 78 Jimmy
drilled some holes bolted right up tilt dial to the outside not all years have two arms great for long drives
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-12-2013, 10:32 PM | #13 |
Doesn't seem to be to easy to find the burb seats locally.... Really looking forward to it after seeing everybody else's
12-13-2013, 01:02 AM | #14 |
Took me 6+ months of searching before someone parting out a burb popped up...I was specifically looking for gray 88-91 seats however. I did have to drive about 60 miles to get them...but worth it, no rips or sagging foam.
12-13-2013, 03:20 AM | #15 |
Just curious what were they selling for. Curious if I would be better off price was buying mounts and getting seats instead of pulling out a burb
12-13-2013, 08:18 AM | #16 |
78K & 79C Jimmys
I would expect about $100 for two nice ones,sold the 87s for that with rips ,just sold my old 2 Jimmys for $40,very rough
12-13-2013, 04:52 PM | #17 |
I paid $125 for the seats including the console and all brackets
12-13-2013, 07:55 PM | #18 |
I put 'Burb seats in my 85 standard cab, but they don't have enough room to scoot back enough to be comfortable for me, and I'm only 6 foot 2. They hit the back of the cab. I was trying to use the burb supports but ended up cutting my old bench seat support up and welding up a mismatch of stuff to match the holes. I think if you could find a PU with buckets those supports would work much better.
12-14-2013, 01:17 PM | #19 |
The burb seats require drilling the inner rear whole and mounting the front inner perch. I'm only 5'11" and I do have the seat all the way back..very comfortable..
12-14-2013, 04:37 PM | #20 |
Here's a pic of my 86 K10 interior after completing about 95% of the interior restoration. I used 1990 Suburban bucket seats, console, seat/console brackets, Suburban seatbelts and black plastic door sill plate covers, fold-over style door pockets and I even swapped out the Silverado door panel inserts for the Suburban ones after trimming them down and using 3M spray adhesive to bond them to the pickup door panel insert backing.
