Painting wheels white.
Does anyone know the official white color of the white tops on the blazers? I guess it's sort of pure brilliant white???
How do I make sure it's s a close as possible if I'm doing it with a can? ALSO and importantly - are there any tips in terms of painting pre-primed wheels to get the best finish. I will of course remove grease and dirt dust etc, but I've never done any auto finish spraying before. Tips would be great. |
Re: Painting wheels white.
1. Sanded/wire brush to remove old paint and rust.
2. Used POR-15 on the outer lip, around the valve stem, and where the center parts are riveted to the outer part of the rim. 3. Primed and painted GMC "pure white" from a spray can 4. Gloss clear coat |
Do I need POR-15 if the wheel is new and pre primed??
I know the pieces fit
Not if they're new/in primer. Just scuff them up well so the paint will stick.
78K & 79C Jimmys
had a flat late summer had to get new rubber
Not the right white but I just used "tremclad"rust paint I've heard it called frost white? I'd throw them in the back of the truck windows closed,in full sun dry/hard in no time!
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
