12-11-2013, 07:51 PM | #1 |
Tilt Column
I'm seeing tilt columns come up for sale every once in a while. I have a couple of questions.
I've never really thought about installing a tilt column in my truck. Unfortunately though; it seems the older I get, for some reason yet unknown to me, my cab and in particukar the distance between my steering wheel, and seat is getting smaller. Was a tilt column available for a 4 speed floor shift? The ones I've seen on the board all seem to be for automatics. Are there any major issues to install? Especially since my column is already out. It looks like everything is the same except at the top where it will tilt. So it appears to me that it just installs like non-tilt.
A man's thoughts devise his ways; but it's GOD that directs his steps. |
12-11-2013, 08:12 PM | #2 |
Moderator
Re: Tilt Column
Installs very easily. There are 4 speed tilts out there, but they are harder to find.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-11-2013, 08:29 PM | #3 |
Re: Tilt Column
There is one listed right now on Craigslist. It's in Auburn, Alabama. $400 and it looks pretty good.
12-11-2013, 08:39 PM | #4 |
Re: Tilt Column
Does the pick up and van column interchange?
12-11-2013, 08:51 PM | #5 |
Re: Tilt Column
I agree, you can find a floor shift tilt. They are fairly rare and usually command a higher price than an auto tilt.
Yes and no. You have to modify the intermediate shaft, the wiring harness will usually have the flat plug instead of the half moon, and the neutral safety switch is usually too low, but all of those things are easily overcome.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-11-2013, 09:14 PM | #6 |
Re: Tilt Column
Here is what I did to a much cheaper van tilt[$75 bucks]. I took off the shifter indicator then welded up the screw holes then I knocked out the shifter retention pin[ it was a little loose and wollowed out, the reason for the $ 75 price tag]. Then i ground off the shifter "hump" and the last mod I did before the cosmetics was to place the shifter arm [at the bottom] in what would be the park position.Once that was done I tacked the arm to the tube so that it could not move. After that op was done, I cut off the arm and ground smooth the ends so it would look good. Next I filled the large holes [the one where the light goes and the one where the shifter went. The one where the light went, I placed a small piece of tape under the hole for backing then filled with short hair fiber strand. After the holes were filled and sanded smooth, I primed it with 2 coats of high build primer. The next step will be to paint it body color and reinstall or in this case install as the truck was a 3oot and I am changing to a T-5. Easy Peasy, and it will appear as though it came with a factory tilt. Jim
12-12-2013, 04:06 AM | #7 |
Re: Tilt Column
I should have asked this in the original post. What years will fit? Will an early 80's fit also?
I may start watching for one. Hugger; you make it sound easy. Usually with you talented guys, when you say easy, it usually means the rest of us will end up giving up w/o success.
12-12-2013, 08:12 AM | #8 |
Old member
Re: Tilt Column
I installed a orignal 4 speed tilt out of a blazer years ago. My buddy and I spotted it in a junkyard. The blazer was burnt up and the steering wheel melted off of it. The sticks were gone also.
I payed the guy $40.00 for it and he took it out. We took it back to the shop and blasted it and installed all new bearings and stuff. It's been in the 71 ever since 1990. U want regret it if U buy one no matter how U get it.
12-12-2013, 08:42 AM | #9 |
Re: Tilt Column
The van columns go up to about 81 I think. Also motor homes are a great source for them and they look much closer to the truck tilt than the van tilt, and they go until 85 that I know of for sure because I have an 85 with the tilt and the main diff is the arm angle is a slight difference [on the shifter at the bottom] I have two of those motor home tilts one van tilt and one truck[ none for sale they all have project homes]but If I were to do this shifter removal again [it only took a couple of hours tops] I would try my best to find a cheaper van tilt or a motor home tilt. Then you could use that leftover money elsewhere. Jim
12-12-2013, 09:24 AM | #10 |
Re: Tilt Column
CPP has a brand new chrome tilt with all GM internals for $189.00 and free shipping ! on e bay .
12-12-2013, 09:47 AM | #11 |
Old member
Re: Tilt Column
That is a steal at that price.
12-12-2013, 10:08 AM | #12 |
Re: Tilt Column
I bought a reproduction tilt column from one of the "big" catalog companies that sold for $329 in October of 2010. It turned out to be made in China and isn't made as good as the originals. It has a lot more play in it then an original would have. I learned the HARD WAY to pay a little more and get something made . . H E R E !!! . . . . |
12-12-2013, 10:32 AM | #13 |
2WD Jimmy
Re: Tilt Column
12-12-2013, 11:37 AM | #14 |
Just like to part out trucks!!
Re: Tilt Column
John finding a four-speed tilt is very hard, four hundred dollars is a great price for one, I bought one a year ago for $425 shipped but after I redid it I got over 500 in it now
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
12-12-2013, 02:59 PM | #15 |
Re: Tilt Column
Thanks again everyone for all your help. It's greatly appreciated.
I looked at LMC (not to buy) but for comparison. LMC says with theirs; I would also need to buy a different steer wheel (from them), and a steer wheel installation kit. I'll have to look at the junkyard? I called about the unit on Craigslist. Waiting to hear back.
12-12-2013, 03:36 PM | #16 |
Re: Tilt Column
Are the CPP columns made in the U.S.A.?
12-15-2013, 09:55 PM | #17 |
Re: Tilt Column
12-16-2013, 12:28 AM | #18 |
Re: Tilt Column
Don't buy a CPP column. I made that mistake. Terrible quality. If you are going aftermarket go with ididit or Flaming River.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
12-16-2013, 04:27 AM | #19 | |
Re: Tilt Column
Thanks Steve, I bought it. The seller is a really nice guy. He went out of his way to get it shipped the same day I bought it. I hope to have it Tuesday. I know sometimes Craigslist sellers can be on the "odd side", but generally, most of the people I've met from Craigslist were pretty nice. Now..............If I could only earn the money for truck parts as fast as I spend it!
