Removing Door
I want to replace my outer rocker panels because of rust in the flange that the door weatherstrip mounts on. I think it will be easier if I remove the doors. I've been advised that I should remove the doors by unbolting the hinges from the cab. By removing the upper cowl, I can easily get to the upper hinge, but I don't see how I can get to the lower hinge to unbolt it from the cab without removing the fender.
Any thoughts on this? It would sure be easier to unbolt the door from the hinges, but I don't want to have problems getting it aligned when I put it back on. I've read that some have drilled 1/8" holes through the hinge and door and then insert 1/8" drill bits to realign things. Does this sound like a reasonable compromise? Thanks for any thoughts or advice. Tim |
Re: Removing Door
You can get those bolts but it's hard. You need to remove the bottom fender bolt (down there in the rust pocket.) This will allow just enough flex to gain acces with a wrench. Maybe you could also mark the hinge positions with that spray on blue stuff machinists use for marking metal, then you could just wash it off when you're done.
Re: Removing Door
I just removed my doors and used the drill bit trick. I also removed the front fenders so no help there.
The front fenders are real easy to remove. You don't have to remove anything else except the cowl piece which you will already have off. Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
![]() Join Date: Jun 2006
Re: Removing Door
Unless your bolts have never been touched or welded themselves in place with rust like mine.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Re: Removing Door
Tim:
When I replaced my rockers, I kept the doors in place. The benefit of doing so was to make sure I had the rockers lined up with the same door gap across the bottom of the opening. If you decide to take the doors off, you lose this ability. Make sure you take good measurements from the top of the doorway before you cut the old rocker out if you do remove the doors. Regards, Steve |
Re: Removing Door
You can always leave the lower hinge on and remove the bolts from the door.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Removing Door
Thanks for all the information guys! To think this all started with just cutting a hole in the floor for my T5 shifter.
![]() I was thinking the just removing the outer rocker panels woudn't alter the door opening. I am hoping that the inners are intact ans will only need some clean up and primer, but guess I will see. As '63 suggested, I may remove the top hinge at the cab and then the bottom from the hinge after drilling that 1/8" hole for reference. |
![]() Join Date: Feb 2010
Re: Removing Door
Aligning doors isnt that hard. I did it without any help too. They came out pretty close.
Re: Removing Door
I took a center punch and marked my hinge corners.
1961 chevy K10 my build is------------61K10 build |
