12-11-2013, 09:52 PM | #1 |
But Found Her 25yrs Later!
Trade - Tach for Bolt-in Low Hump
I have this Tachometer.
I don't know anything about it. I want to trade it for a bolt-in lowhump floor pan.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-11-2013, 09:54 PM | #2 |
Re: Trade - Tach for Bolt-in Low Hump
This is the low hump I want.
12-11-2013, 11:35 PM | #3 |
LOL!
The low hump pictured is the one I am installing in my truck.... The exact one one in my exact truck! You can't have this hump, but.... I know where 3 more are, I will try and score one of these for you. The weather down here is crap right now so if someone else can do it right away no problem. Otherwise I will get one as soon as weather and time permits Thanks for making my truck famous! :-)
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
12-11-2013, 11:39 PM | #4 |
I copied the pic from your thread. :-)
http://67-72chevytrucks.com/vboard/s...d.php?t=604589
12-12-2013, 02:06 AM | #5 | |
12-12-2013, 10:23 AM | #6 |
Check The Champ, Demonstrator
Could you state which year and model these come from please. Makes it easier for spotting possibilities when scrap yarding.
I imagine you require the front piece that's spotwelded, do you not? I did see on larger thrucks that the front piece was bolted in as well. Interesting, in the exploded view they do not show the covers attached to the cab. Have to find the part numbers for the different parts from some other source.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 12-12-2013 at 10:32 AM. |
12-12-2013, 03:09 PM | #7 |
Cluster King
Who has the tach now? and is it for sale and how much?
Thank you for your time, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
12-12-2013, 04:54 PM | #8 |
I have the tach.
How about $160 shipped?
12-12-2013, 05:06 PM | #9 |
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
12-12-2013, 07:23 PM | #10 |
Cluster King
Not a bad price but I need to find out if the tach needs the EB-9a transmitter to make it work. Does anyone have any idea on that? I know, I have some old vintage Sun tachs that need the transmitter to work. Let me do some research. Thank you, Tom
12-12-2013, 08:23 PM | #11 |
I'm currently doing some research on suntachs.
So far, I'm thinking mine is one that doesn't need a transmitter. Looking at the connection posts, the connection is direct to distributor. Here is a pic of one that needs a transmitter. Notice the connection posts. It even states what transmitters to use.
12-12-2013, 08:41 PM | #12 |
I'm pretty convinced my tach I'm selling above doesn't need a transmitter. It hooks directly to the coil. One post to the distributor coil. One post to the ignition switch, and one to ground.
Check out this post: http://67-72chevytrucks.com/vboard/s...11#post5141711
12-12-2013, 08:42 PM | #13 |
If sigshooter is willing to trade me that bolt in low hump, then I'd like to give him first dibs.
12-12-2013, 08:51 PM | #14 |
I just re-read sigshooter's post saying he didn't know when time and weather would permit.
12-12-2013, 08:59 PM | #15 |
Cluster King
That is not a problem. I am a little strapped on cash now until after the holidays. I am sure I am not the only one.
I hope you can get the low hump you need. I will keep an eye on this and also do some research on the transmitter. It looks like your tach does not need a transmitter, just a wire up and go. Thank you for your time, Have a good holiday, Tom
12-12-2013, 09:06 PM | #16 |
Thanks for the reply.
I'm currently researching to see if there's a way to use it with HEI. I guess there has been some discussion on this.
12-13-2013, 04:04 PM | #17 |
That tach does not need the converter box
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-13-2013, 04:55 PM | #18 |
Cool.
Do you know if there's a way to use it with an HEI ignition?
05-09-2014, 10:10 PM | #19 |
--bump--
05-09-2014, 11:28 PM | #20 |
Still have tach? What is price?
05-09-2014, 11:52 PM | #21 |
$160 Shipped
05-10-2014, 09:39 PM | #22 |
If I can get it to work with HEI is going to be the question.
05-10-2014, 11:39 PM | #23 |
Is tach still available ?
05-10-2014, 11:56 PM | #24 |
still available
05-11-2014, 03:44 PM | #25 |
Did a little research and it looks like a tach filter will need to be installed due to the "noisyness" of the HEI. Will see if I have trading options in my two spare cabs.
I will pass until I check on those cabs. From American Autowire My factory tach will not work with my HEI or electronic distributor. HEI and other electronic distributors create a different signal or pulse then do original points style distributors. For this reason, your OEM tach that was circuited to read the latter, does not recognize and cannot read the signal it’s receiving from the newer style distributor. The fix for this situation is to purchase a tach filter or interface device. They are available through several aftermarket manufacturers. They can be found on most GM cars in junkyards that have factory tachs in them. The factory style filter looks like a condenser with a wire and connector on each end, one of which plugs onto the HEI distributor, and the other onto the tach lead wire. Hooking this filter device in series between your distributor and tach should allow your factory tach to work in harmony with your new electronic distributor. |
