Rocker replacement- will these parts cover everything I need?
I'm getting around to doing the cab sheet metal replacements, and I'm trying to get a list of what I need. From what I've researched on here, top banana is the way to go. Will this cover everything I need? The passenger side isn't anywhere near as bad, but I figure I'll have the parts if I need them. I do need to do the support braces for the driver's side if that factors in.
The rust on the floor is only what can be seen in the pictures, but should I order that part of the floor too? http://www.topbananaparts.com/cab-repair-kit.html Here is the nasty: ![]() ![]() ![]() ![]() Thanks guys.
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
| Bookmarks |
