Roadtrip!
![]() Join Date: Feb 2003
81 and up tow hook question
I just picked up 2 sets of tow hooks for the 81 and up trucks. One set has a slight curve where it mounts and the other set has alot of curve where it mounts. I know the ones with less curve are the common ones. What application is the other set? That is the second set i have seen with the extreme bend in them. Rears maybe?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: 81 and up tow hook question
Holy moly! I am curious now as well, I have never seen the extremely bent ones.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
I'd say the bent one ,. is jus that bent lol
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
Roadtrip!
I don't think so, I have a left and right like that and its the second pair i have had with that much bend.
Roadtrip!
Someone must know something about these. It is factory... Also the second set of them i have owned.
Roadtrip!
Anyone care to venture a guess even?
I'm game. The pair on the left is from a 2wd. Right shows a 4x4 pair. Believe the 4wd trucks had a longer air dam so the hooks needed to be lower.
#8 | |
Roadtrip!
Thanks for your input.
Windy Corner of a Dirty Street
I agree with Oldriginal86. Ill go in with the tight curved ones belong to a 2wd. There is also a third set for 81-91 that you dont see often but we ran across some at the junk yard the other day. The third set are much larger very similar to the 73-80 hooks. After I grabbed the usual pair for my Burb member Zoomad75 grabbed the big ones from a 1 ton chassis cab. Not sure if the large ones were an SEO or typical of 1 tons.
This is a picture from elsewhere on the web, but the large ones like Zoomad75 found the other day are like the two rustier hooks below.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Roadtrip!
So we are thinking 2wd on the really bent pair.
Dirtylarry, i can't see your pic but would like to if you can load it. Thanks.
K5Camper
![]() Join Date: Mar 2004
Here's the ones we found the last weekend. These are thicker than the standard 81 and up hooks. We found them on a 1 ton Cab and Chassis. Everything else is similar in the bends and mounting to the standard hooks. I'll I can say is these things are BEEFY.
[IMG][URL=http://s445.photobucket.com/user/zoomad75/media/Mobile%20Uploads/NCM_0178.JPG.html]
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
I pulled a set of the beefy ones from an 81 3/4 ton. What year was the cab and chassis? I'm thinking the beefy ones could a 1 year only 81.
#13 |
Roadtrip!
Thanks for the pic zoomad. So it looks like 4 styles of tow hooks used from 73-91...
Ray, you have a set like the ones pictured by zoomad? Or mine?
#14 |
All of my sets of tow hooks were pulled from 4wd and none of them have the extra bend so I think they must be 2wd. The set from the 81 has a similar girth as the 73-80 ones. I bet GM figured they could save 2 cents per truck by thinning up the hooks.
#15 |
Looked at mine tonite, they look like the right ones in the post 5 pic.. My truck is 2wd. Hope this solves the mystery.
#16 |
The chassis cab Zoomad and I got them from was an 89 or 90 but still the square body style. I snagged the hydraulic clutch pedals from this same truck a few years ago. I'm thinking the beefy hooks were either an SEO option or sold as GM accessory.
#17 |
That's probably the case. The 81 truck wasn't even heavy duty as it had a semi float rear end. And some of my hooks came from 88-91 crew cab 1 ton 4wd and they were the regular hooks.
#18 |
Just for contrast here are a couple pics of an original set from my 1977-1980 K30 trucks.
#19 | |
![]() Join Date: Jul 2001
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
