Old 12-12-2013, 01:18 PM   #1
dracko
dracko's Avatar
Upper rad hose for V8 rad to L6 engine
I recently swapped in a larger V8 rad from LMC, but haven't gotten around to swapping out the 230 for a 327 yet.
Just wondering if anybody knows a PN for an upper rad hose that will work between the 230 and larger rad? Or am I stuck using the universal flexible hoses.
dracko is offline   Reply With Quote
Old 12-12-2013, 01:55 PM   #2
1963c-10
1963c-10's Avatar
Re: Upper rad hose for V8 rad to L6 engine
I used a universal flex hose myself. I went to O'Reillys at the time and they let me go through everything they had hanging. No luck. So I just got a universal flex hose. No issues since 2009.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-12-2013, 02:33 PM   #3
cg285
i used molded hoses on mine but don't remember the #'s. i'll look tonight and see if there are #'s on the hoses or if i put a note in the glove box.
cg285 is offline   Reply With Quote
Old 12-12-2013, 03:06 PM   #4
Sharps40
Here. Part numbers depicted in the photos. Original I6 lower and Universal hose upper, both Gates installed on an Autozone V8 C10 3 Core Radiator. Radiator Top inlet is 1.75" and I6 Waterneck is 1.5"
http://67-72chevytrucks.com/vboard/s...d.php?t=599562
Sharps40 is offline   Reply With Quote
Old 12-12-2013, 03:12 PM   #5
dracko
dracko's Avatar
Thanks for the replies! My other universal hose was clearly too long because it crimped at the bend after a short while, thankfully it didn't close it off completely and it's freezing cold up here. Picked up a 15" with 1.75x1.5 ends and it fits good. Moulded would be nice, but this'll do til the v8 goes in.
Old 12-12-2013, 07:55 PM   #6
slimbailess
slimbailess's Avatar
try looking at hoses for a 70? impala, they had 1 3/4 radiator inlet
slimbailess is offline   Reply With Quote
Old 12-12-2013, 08:02 PM   #7
63burban
Chevy addict
I used a modified upper V8 hose for a 1974 Chevy truck, lower hose is a modified 6 cyl with a Speedway aluminum V8 radiator for a stock car. 250 engine
63burban is offline   Reply With Quote
Old 12-12-2013, 08:40 PM   #8
Lugnutz65
Lugnutz65's Avatar
I hope this helps. I have a 250ci (same block as a 230ci) and I recently installed a WIDE Harrison radiator in my truck (first picture). I say "WIDE" because it was NOT tall and narrow like my original 230ci Harrison radiator (2nd picture).
Anyway, I found perfect fit pre-molded hoses. The lower hose is NAPA 7133. The upper hose I ordered from Summit Racing. It is a Goodyear 60017 and you can see I had to trim off a little.
If you look at the side view you can see my radiator saddles are on the upper rail of the frame cross member because I have a fan spacer. Even if your radiator is in the lower position closer to the engine, the same hoses will work, but will need different trimming.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 12-13-2013, 12:42 AM   #9
dracko
dracko's Avatar
Hey thanks Lugnutz. Those hoses looks like they fit great. My rad is also on the upper rail like that so should work good.
