12-12-2013, 03:28 PM | #1 |
newbie here!! 8.1 into 67-72 anyone go thru with it ??
Hey guys. Newbie here but ive been lurking for a few years now. Bought my 67 c-10 about 4 years ago. I recently tripped over a 2002 express 3500 with the 8.1 4L85e. It has finally pursueded me to dust the old girl off and dive in. Been searching all over the board. However, the only posts I seem to find are from guys that wanted to do it but have been persuaded not to. Mainly for the lack of and price of the aftermarket for the 8.1 or the popularity of the 6.0 and ls small blocks. I have yet to find someone that went thru with it except for the one guy with a square body. Dirtylarry I believe?? Has anyone gone outside the popular crowd and done one in the 67-72s?? Or am I gonna be the first and have to set out on my own?? I have aquired alot of priceless info and seen alot of great ideas from you guys. Looking forward to throwing in my $.02 from here on out.
Thanks!! Nate |
12-12-2013, 03:57 PM | #2 |
Re: newbie here!! 8.1 into 67-72 anyone go thru with it ??
Welcome!
Watching as it is something I once considered but never was able to fund.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
12-12-2013, 05:58 PM | #3 |
Heres a couple starter pics. One the day I brought her home fresh from tennesee. And one from last weekend peeling her open!!
12-12-2013, 06:02 PM | #4 |
Should be a fairly straight forward swap, everything for a BBC bolts up however make sure to save and re-use all the hardware for the engine mounts and everything as it's all metric.
12-13-2013, 08:50 AM | #5 |
There is a link on the Street and Performance website by Gary Puls on an '88 1-ton.
http://www.hotrodlane.cc/81%20swap.pdf the 8.1 is a tall-deck big block. It looks like it should bolt in like a big block, move the transmission crossmember and cut down the driveshaft. If you use the new style accessories, looks like to have to notch the frame for the a/c compressor. If you don't want new style serpentine accessories, you can probably find old school accessories on a 366 powered schoolbus for just power steering and alternator. Exhaust manifolds may be an issue. Other than that looks like a pretty straightforward swap with all the little things that go with any retro-mod swap.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
12-13-2013, 10:02 AM | #6 |
I have sold several of the 8.1 engines. my last customer put one in a 69 chevelle. it turned out really neat. when you open the hood NOTHING fills up the engine bay like a big block chevy!! and dart machinery www.dartheads.com is making peformance parts for them now you can even buy a new 8.1 engine block. a LSX engine runs good but the 8100 is a torgue monster. 496 cubic inches and lots of people can wire them up. good luck with your swap!
12-13-2013, 10:15 AM | #7 | |
12-13-2013, 10:25 AM | #8 | |
12-13-2013, 10:35 AM | #9 |
please take lots of pictures.....oh and post them....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
12-13-2013, 11:11 AM | #10 |
12-13-2013, 11:41 AM | #11 |
Welcome, that step side will be a beast with the 8.1, as the others have mentioned it should be a fairly straight forward swap in the c10 chassis, I have installed one in mine but it is a 1972 4x4. there are a few people around with knowledge. Dirty Larry is the guru on here and has posted a lot of information and photos both here and other websites like CK5.com
http://coloradok5.com/forums/showthread.php?t=308019 do a google search and you will find quite a bit of help, Good luck with your swap and I will be watching as well should be fun!
My build: Project "Lazarus" 8.1 Vortec and Allison in a 72 swb k10 http://67-72chevytrucks.com/vboard/s...d.php?t=555878 |
12-13-2013, 12:42 PM | #12 | |
12-13-2013, 03:31 PM | #13 |
Sure, here is my build thread, http://67-72chevytrucks.com/vboard/s...d.php?t=555878
I still have a long way to go, and will be pulling things back apart for paint, I wanted to get everything mocked up first.
12-13-2013, 04:17 PM | #14 | |
12-13-2013, 04:27 PM | #15 |
Thanks for posting the build threads. You guys made me feel better that I didn't try it. I just don't have the welding skills to cut frames, firewall and mounts.
Good luck on your build n8r67
12-13-2013, 10:58 PM | #16 |
The aftermarket is gonna catch up slowly to the 8.1 crowd they will have to. A lot of people dismissed that motor at first but is is a rat cousin right? I would think that Comp in Memphis could whip you up a hyd roller if they don't already have a range of profiles to choose from I haven't looked in their catalog that really would wake it up. there is probably at least a hundred HP and a hundred FT.LBS resting in there waiting to be brought out with a simple cam change. Jim
12-14-2013, 05:43 AM | #17 | |
