Old 12-13-2013, 02:01 AM   #1
c10 custom
one piece driveshaft
hi guys i own a 1968 chev truck shortbox 2wd fleetside and i am wanting to swap the turbo 350 transmission for a 700 r4 and i want to swap to a one piece driveshaft can i buy the driveshaft somewhere or do i have to measure it and get it made any help on this would be great pictures too thank you everybody
c10 custom is offline   Reply With Quote
Old 12-14-2013, 11:08 AM   #2
msgdsrf
Re: one piece driveshaft
No one else has chimed in so I'll give my opinion, I replaced my driveshaft with one piece. You'd think it a no brainer for this to be a known length, but just wait and measure you particular setup when you are there. A driveshaft can then be made and balanced in a day, probably in Bozeman.
msgdsrf is offline   Reply With Quote
Old 12-14-2013, 11:23 AM   #3
Lee H
Lee H's Avatar
Best to get the engine and trans mounted then do the measurement. Length will be impacted by which differential you have, coil or leaf, which engine mount holes you are using, and I think there are different length tail shafts. Visit a driveline web site to learn how to measure and what info is needed to pick out the correct components for your application. Inland Driveline has a great tutorial with video on how to do this.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-14-2013, 01:41 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
I have swapped 700r4's into a couple of trucks over the years. I used the stock driveshaft out of late 80's trucks, the same that the trans came out of. The latest was a swb, 54-1/2" IIRC.
WIDESIDE72 is offline   Reply With Quote
Old 12-14-2013, 05:53 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
"A known lenght" sure if there wasn't a half dozen locations the engine and trans could be mounted using only stock parts.
Measure YOUR truck at ride height with the engine and transmission installed. Call a DRIVELINE shop and have them build you a shaft to your specs and have them BALLANCE the shaft after it has been ASSEMBLED. You can order premade shafts from parts houses but then you have to ad the trans yoke and ujoints, that's like ballancing your wheels before you install the tires.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
