Old 12-13-2013, 08:09 AM   #1
1967Bowtie
1967Bowtie's Avatar
Carburetor Problem
I am having a problem with my 2 Barrel on my 1967 C20 its a 283 with an automatic and manual choke Rochester. I recently took it off and rebuilt it I soaked it in a gallon of the carb cleaner blew out all the holes and put a fresh rebuild kit on it. I set the float level and had it ready to bolt back on. First I cleaned all the junk out of the channel of the manifold where the carb bolts up also. Anyway I got it all back together started the truck dialed in the mixture screws it runs smooth at idle but when give it gas it bogs down, while under the hood I noticed it was leaking at the base gasket and around the mounting bolts. I removed the carb again the gasket was soaked so I have another to replace but I also checked the float level again and the accelerator pump to see if it was a problem but nothing. I put it back on the truck still having the same problem. What am I missing?
1967Bowtie is offline   Reply With Quote
Old 12-13-2013, 08:20 AM   #2
hugger6933
Re: Carburetor Problem
Needle and seat problem maybe but that would throw off the idle. Also sounds like the float may be too high. Good luck
hugger6933 is offline   Reply With Quote
Old 12-13-2013, 11:19 AM   #3
Grumpy old man
Grumpy old man's Avatar
Vacuum leak
Grumpy old man is offline   Reply With Quote
