07-16-2003, 11:37 AM | #1 |
Can a 68-72 steering box be used in a 63?
I'm thinking of purchasing a 63 lwb that needs a new steering box. I would like to install power steering and was considering using a box I have from a 72. Can anyone tell me if I can swap the two, and if there are any other components which need to be changed?
Any info is appreciated. Thanks. |
07-16-2003, 12:11 PM | #2 |
Project Junkie! Fishing Poor!!
The side of the chassis on the 63 is flat and in order to install a 69-72 steering gear it will need to be dented in between the bolt holes. You will also have to drill one hole, because the 63 only has 3 and the 69-72 Power steering gears require 4. You can install thick washers between the steering gear and frame rail, but that results in running the gear off center and that makes the steering ultra sensative. (Dangerous in my opinion). WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-16-2003, 12:26 PM | #3 |
Wes, thanks very much for the quick response.
If I recall correctly, isn't there a conversion kit available, or was it only for 67/68 with the flat rail? Thanks again. |
07-16-2003, 11:27 PM | #4 |
Anyone else have any suggestions?
07-16-2003, 11:46 PM | #5 |
huh?
67 and very early 68 ONLY for the flat rail as far as I know (in the 67-72 years that is)
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
07-17-2003, 02:09 AM | #6 | |
Now the others dig........
Hmmm...
Sorry to butt in...but I think everyone would be interested in hearing about that.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 Last edited by SWINGSAX68; 07-17-2003 at 02:11 AM. |
07-17-2003, 02:10 AM | #7 |
also would that result in a cracked frame?????
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
07-17-2003, 10:15 AM | #8 |
Fabricate till you "puke"
there is a conversion kit for the power steering on the older trucks. try this link... http://www.classicperform.com/power6066.htm Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-17-2003, 10:36 AM | #9 |
Thanks crazy, that's exactly what I was looking for!
