Old 07-16-2003, 12:14 PM   #1
VNMOUS
Step Side's Rule
Idle?
What is the proper idle RPM?
DANO
07 Silverado Classic
67shortstep
76 stingray
95 cobra
66 Mustang Coupe 289
VNMOUS is offline   Reply With Quote
Old 07-16-2003, 12:25 PM   #2
69sixpackbee
what engine? Cam?
69sixpackbee is offline   Reply With Quote
Old 07-16-2003, 02:36 PM   #3
SuperCheyenne72
SuperCheyenne72's Avatar
Smile Here's my 2 cents!
Mine Idles at around 750 RPM at red lights...
It jumps to around 850 in neutral and park...
It sorta fluctuates depending on the weather and if the ol' boy has been warmed up enough... (which doesn't take long in this Texas heat!)
check sig. below for what I drive...
'72 Super Cheyenne LWB
  • 350 V8 w/ TH400
  • MSD Pro Billet HEI Dist. w/ Splitfire plugs
  • Edelbrock Performer Intake Manifold and dual exhuast glasspaks
  • Edelbrock Performer 750 cfm
SuperCheyenne72 is offline   Reply With Quote
Old 07-16-2003, 02:47 PM   #4
VNMOUS
Step Side's Rule
355 V8, CAM-234 DEG, 488 LIFT
DANO
67shortstep
76 stingray
95 cobra
Old 07-17-2003, 10:18 AM   #5
SuperCheyenne72
Question It just occurred to me...
By the way,
If my tach is reading 750 RPM, what does that mean? What is spinning at that fast of revolutions? Is the spinning point inside the distributor spinning that fast? Is it the flywheel? I seriously have no clue?
  • 350 V8 w/ TH400
Old 07-17-2003, 10:21 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's how fast the crankshaft is spinning. As well as flywheel, clutch, harmonic balancer, yada, yada, yada...
FWIW, The cam and distributor spin at half that speed
Old 07-17-2003, 10:54 AM   #7
69sixpackbee
The cam and the distributor are spinning at 1/2 engine speed FYI. Yes, RPM is the actual revolutions in 360 degree increments per minute of time of the reciprocating assembly. If you could see the front of the cranksshaft spin once completely around in one minute that would be 1 RPM and the camshaft would have gone just half-way around. It is a 2:1 ratio.
