12-13-2013, 07:36 PM | #1 |
Exhaust Manifold Bolts
Is there anything special about them? I'm putting in a new engine and was planning on reusing the old ones, but they are pretty well rusted, so I want to replace them.
Are they grade 5, grade 8, something else? It's a stock manifold on a stock 307. Thanks in advance.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
12-13-2013, 07:45 PM | #2 |
Re: Exhaust Manifold Bolts
I could be wrong, but if you do replace the bolts, if they are bolts, I'd use grade 5 or better and coat them with anti-sieze. I'd use a tap or thread chaser in the old holes to make sure there was no flakes left to gall the new bolts. If they are studs I think I'd use brass nuts. That advice is probably worth what it costs, it's free.
12-13-2013, 07:50 PM | #3 |
One of the old ones for reference.
12-13-2013, 08:29 PM | #4 |
I've re-used the manifold bolts many times over, and have had minimal issues.
I pick out the best ones from my selection and put new lock washers on them. I I have never used any anti-seize on them.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
12-13-2013, 11:27 PM | #5 |
I used grade 8 bolts but I'm pretty sure grade 5 was stock. There is no reason in my mind to use the old bolts. Just buy new ones with lock washers. You might spend $10. Worth every penny. The old ones are rusted, weak and worn.
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
12-14-2013, 12:05 AM | #6 |
I seem to remember the length was something like 2 3/4" which isn't usually found at the local BORG.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
12-14-2013, 02:53 PM | #7 |
I had to get them from the dealer. Regular over-the-counter bolts are either a tick too long or a tick too short.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
12-16-2013, 01:48 PM | #8 |
If you have a Caterpillar dealer nearby, they have nice GR8 case-hardened bolts in 1/4" increments so you can find the 2 3/4" long. You might get them in GR8 at Lowes or GR5 or 8 at a bolt store in a larger city.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
12-16-2013, 05:01 PM | #9 |
Ace Hardware is your friend. If there is one near by, give them a try.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
12-16-2013, 05:42 PM | #10 |
New Member
I've bought all kinds of stuff from McMaster-Carr for many projects throughout the years. They have lots of stuff you won't find elsewhere and usually their shipping is fast. Huge catalog that has ended up as a "sit down reading material book".
http://www.mcmaster.com/#
Steve 67' C20 - Newest - My junkyard dog and work in progress |
12-16-2013, 05:53 PM | #11 |
Junior Member
I got stainless ones from Fastenal and I have 11k miles and no leaks.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
12-22-2013, 10:53 PM | #12 |
I would definitely replace them. The chance of an old bolt snapping off in the head makes it an easy decision for me. Those bolts see a lot of heat cycles.
I have factory air, so my truck has 3 or 4 different size bolts. I think I ordered them from Brothers or Classic Industries; can't remember for sure. I used anti-seize. On the 350, the torque spec was different for the inside bolts. Not sure if it's the same for the 307. |
12-23-2013, 09:20 AM | #13 |
+1 on That.. I tend to replace all the hardware in the engine compartment with cap head stainless hardware from Fastenal. I also tend to use copper anti-seize on any dissimilar metals, especially when going into aluminum.
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
12-23-2013, 12:47 PM | #14 |
Old member
It's always good to use new bolting material when you can and always put anti seize on any bolt threads, flat of head and on the flat washers. No need to put it on lock washers though.
Grade 8 is over kill for this app., grade 5 may even be a little over kill.This isn't holding anything that would cause bodly damage if it broke.
