12-13-2013, 07:42 PM | #1 |
need to lower my 70 lwb
I would like to know how low I can go with my 70 lwb with out doing a c notch and how low with one. Do I need springs and spindle's or just spindle's in the front. Who's kit would be good to use. Right now my truck sits on new stock sb springs in the front and new stock springs in the rear. I want it to be level and at what point do I need to run the exhaust through the frame where the trailing arms attach. Any info would be good and some pics of finished trucks would be even better.
Thanks, Wes |
12-13-2013, 07:44 PM | #2 |
67-72 parts collector,…
Re: need to lower my 70 lwb
www.earlyclassic.com 4.5/6 drop is what I would use.
12-13-2013, 08:32 PM | #3 |
Just considering 'with a notch' .. about 7.5 is about all I would do on a static drop. Any lower and the rear axle housing gets super close to the bed floor. Keith is the man. 4.5/6
2.5" spindles, 2" springs up front. 5" springs, 1" block in the rear. It will ride a little better than a straight up 6" spring. .. 6" springs are very common but the 5, or even 4/2 combo gives the spring a little more efficiency plus if its too low you can change the block and its not a 6" or stock scenario. Just a different perspective on it. Good luck with it.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
