Old 12-13-2013, 08:34 PM   #1
1970/327/c10
1970/327/c10's Avatar
Fuel Mileage question??????
I have a 1970 chevy k20, with 4:11 gears, 350 bored 40 over with 650cfm edelbrock carb and intake and mild rv cam, I have a 700r4 that i want to drop in my pickup. What kind of mileage would i be looking at.
Drivin People Insane With my Classic Chevy!
1970/327/c10 is offline   Reply With Quote
Old 12-14-2013, 12:28 AM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Fuel Mileage question??????
Crappy. Lucky to get 10 out of that combo.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-14-2013, 02:41 AM   #3
1970/327/c10
I dont see were you get that i get 10 now with my 350 trans and thats with out overdrive, and the 700r4 has overdrive...
Old 12-14-2013, 11:11 AM   #4
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
what size tires do you have now and will they be the same with 700R4?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-14-2013, 12:42 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
There are so many factors that influence fuel mileage, it's impossible to say what you will get. As asked above, what tires are you running? If you get 10 mpg now, you might pick up another 1, maybe 2 at best, but that's about it. The best I ever got with my K20 (350, 4.10s) on a long trip was 11.5 mpg, and that's back when I was still running the stock skinny hard 7.50-16s.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-14-2013, 08:01 PM   #6
1970/327/c10
I have 33 eldarados, not really bigger than stock, just have an aggressive tread.
Old 12-15-2013, 12:15 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
33s are somewhat taller and certainly wider than stock tires, and that hurts fuel mileage. Wider tires often run lower air pressure which also hurts. Something like a 235/85-16 is probably about the right height (depending on your OEM tire size) and skinnier, and can run higher pressure -- which helps increase fuel mileage.
- Mike -
RIP El Jay
Old 12-15-2013, 12:22 AM   #8
1970/327/c10
I would get you the exact tire size but the pickup is in the shop at the other house, heres a picture when i was rebuilding the frame.
Old 12-15-2013, 03:08 AM   #9
andrewmp6
Real world you will pickup 1 to 5 mpg probably with it.
andrewmp6 is offline   Reply With Quote
