Old 12-13-2013, 11:09 PM   #1
oleguy
283 V8 looses oil pressur at driving temperature
I am about to acquire a 283 out of a 66 chevy pickup.To put in my 67 C10. It was recently (overhauled) by a previous owner. The oil pressure is good at low to medium temperature, but at running temp. it drops to near zero. My thoughts are #1. Main bearings to much clearance. #2. Cam bearings to much clearance. #3. I don't know if the oil pump was replaced or even checked. I will tear the engine down and check these items. Any further ideas on the the cause of this problem will be appreciated. Thanks in advance.
oleguy is offline   Reply With Quote
Old 12-13-2013, 11:13 PM   #2
Rod Run
Rod Run's Avatar
Re: 283 V8 looses oil pressur at driving temperature
Sounds like a possible bad pump. whatever it is, I would stay away from it unless you are buying it under the idea that it is going to need an immediate rebuild? Must be priced accordingly. free?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 12-13-2013, 11:14 PM   #3
cool68
what are you relying on to give you correct pressure reading? what are the pressure readings?
cool68 is offline   Reply With Quote
Old 12-14-2013, 03:00 AM   #4
swamp rat
swamp rat's Avatar
Could be all the above, and it could be the wrong weight oil too. Ask the guy if the mains were plasti gauged when rebuilt and see what he says, i cant remember the clearance off hand but i think about .001 to .0015? If he rebuilt it doesn't know then he has no business rebuilding an engine in the first place. If he has no answer on the plasti guage he could have probably just slid a new cam into the old bearings too. I don't know the guy obviously but this is what i'd be thinking.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-14-2013, 08:55 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: 283 V8 looses oil pressur at driving temperature
As stated see what the real pressure is and it's normal for oil presssure to drop off after reaching running temperature. Mine reads high when first cranked up but after she is running it will drop off a bunch around 25-40PSI. Get a good trusted reading yourself.
5lbs of oil pressure is not un common at idle.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-14-2013, 10:39 AM   #6
Eddie H.
Eddie H.'s Avatar
Most every small block chevy I have ever owned showed low oil pressure at idle after they are fully warmed up. As long as you have at least 5-10 psi, I wouldn't worry about it.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 12-14-2013, 12:03 PM   #7
Sammy
If it is actually zero that isn't good. I wouldn't install anything with that low of pressure. Too easy to investigate that and figure out a reason while it is out. Likely it is just the pickup screen on the oil pump too high to suck up the oil.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-14-2013, 12:27 PM   #8
cwilkie
Chance
cwilkie's Avatar
Try a different oil filter. One of my engines had extremely low oil pressure after it was rebuilt. It had a Fram filter on it. It switched to an ac delco and the oil pressure remained high ever since.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 12-14-2013, 04:41 PM   #9
Sammy
I have heard that before.
Old 12-14-2013, 08:27 PM   #10
myyamr7
myyamr7's Avatar
I remember the machine shop telling me a small block only needs 5psi of oil pressure per 1000 rpm.
I have a new GM goodwrench 350 in my truck and it has 65psi when cold started, stays about 50 when warm and driving, but drops down to 10 at idle when it's hot
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 12-27-2013, 12:43 AM   #11
oleguy
I have been off of the computer for a while, but I want to thank all of you for the help. I will mic. the main and rod journals as well as plasti gague them. I will replace the cam bearings. I will check the oil pickup screen and height, and replace the pump. Once again thanks for the info.
Old 12-27-2013, 02:29 AM   #12
Grip
Grip's Avatar
In the circle track racing world, the rule of thumb is 10lbs per 1,000 rpm. I think you are fine. Clearances are just a little loose.
Grip is offline   Reply With Quote
Old 12-30-2013, 03:54 PM   #13
oleguy
Red face Re: 283 V8 looses oil pressur at driving temperature
OOps. I just reread my original post and neglected to mention, at highway speed (75 mph. on turnpike & 65 mph on secondary Highways ) when the engine warms to normal temp. the oil pressure drops to near zero. Thanks again for all of the input.
Old 12-30-2013, 04:25 PM   #14
67 chevelle
67 chevelle's Avatar
not good at all
67 chevelle is offline   Reply With Quote
Old 12-30-2013, 11:37 PM   #15
zeldman
zeldman's Avatar
Ok,different problem. Check the oil return galleys and make sure they are not sludged up and restricting the oil returning to the pan. Have you tried checking the pressure with another gauge?
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
