Crew Cab guru's
I'm the new owner of a 90 GMC R35 with a VE pumped cummins. My question to the crew cab gods is what's the differences between the c30, c35 and r35 trucks? I've searched everywhere and can't fine an answer. I want to order a 5/7 kit from western but I want to be sure that there isn't anything different with my truck vs c30/c35 trucks.
When did GM start using the Dana 80 in these trucks? Last edited by plumbers crack; 12-13-2013 at 11:37 PM. |
Re: Crew Cab guru's
1990 GMC R35 CC dually, VE cummins, 47RH 2005 Silverado ecsb, 5.3, 2/4 drop, daily work wagon 2000 Yukon xl, 5.3 all stock, wife's truck 2007 Yukon Denali, 6.2 back up truck |
GoatLube Experss
![]() Join Date: Oct 2009
Re: Crew Cab guru's
that nice truck !
as far as I know C30 - R30 and R35 should be the same, I think they went to the 35 in 88 .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
Re: Crew Cab guru's
Dana 80's, if I'm correct, first showed up in 93 or 94 in the 3500HD's. They were 10 lug. Your truck "should" have a Dana 70HD
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
Re: Crew Cab guru's
chevy trucks are c10 c20 c30 the same years gmcs are called c15 c25 c35 they is no difference in them . gm never used the dana 80 under 1991 -1973. they were dana 70 in the dually. the dana 80 was used in the dodges with the cummins thats is proabaly what is in your truck.
4x4k30 if trouble was money i would have plenty |
Re: Crew Cab guru's
Thanks guys, good to know that the c/r 30/35 is just name changes.
I talked to the guy that put it together and he didn't touch the rear, just motor and tranny. Now I need to figure out the gauges and make them work.
Re: Crew Cab guru's
c/k was used until 86, after that they went to the r/v designation.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
| Bookmarks |
