Old 12-14-2013, 12:36 AM   #1
blue57
blue57's Avatar
putting LS car intake on a truck motor
I was wondering what all is needed to swap intakes from the truck style to that of the flat car type? Any advantages or disadvantages? Thank you
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 12-14-2013, 12:52 AM   #2
Beetle
Beetle's Avatar
Re: putting LS car intake on a truck motor
All accessories from the car motor will have to be swapped as well as mounts of said accessories. Looks is about it for advantages. The truck intake makes more torque.
Hope this helps.
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
Old 12-15-2013, 12:01 AM   #3
Blackpony
Blackpony's Avatar
If you are running truck accessories then dirty dingo has an idler relocator bracket.
http://dirtydingo.com/store/product_...oducts_id=1371
Blackpony is offline   Reply With Quote
Old 12-15-2013, 05:47 AM   #4
smoky02
Location: Sunny, Florida, some might call it South Alabama
I'm actually running an LS3 intake(car intake) and I'm running truck brackets, but I did have to order a pulley relocator off ebay though.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 12-15-2013, 10:30 AM   #5
whitels1
whitels1's Avatar
In my 81 I was not able to fit the alternator with the LS1 car style set up, so I used the truck brackets with the Dirty Dingo idler relocation bracket, L92 water pump, and LS1 intake. Worked out well.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 12-17-2013, 01:02 PM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Originally Posted by Beetle View Post
All accessories from the car motor will have to be swapped as well as mounts of said accessories..
Not true.
You don't need the pulley relocator.
Got about 8000 miles on this swap...no issues.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-18-2013, 06:54 AM   #7
smoky02
Originally Posted by Wasted Income View Post
Not true.
[IMG]http://i235.photobucket.com/albums/ee198/jwjost/Monte%20SS%20LSx%20Swap/IMG_4641.jpg
Difference would be that I am running a drive by wire throttle body. Although it looks like your setup would work with that also. What belt did you use?
Old 12-18-2013, 10:32 AM   #8
Wasted Income
Boosted Member
Dayco 5060745
Turbo diesel
Old 12-18-2013, 10:41 AM   #9
Custom 68
Custom 68's Avatar
Did you swap out the newer Camaro water pump to make this all fit?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 12-18-2013, 10:47 AM   #10
Wasted Income
Boosted Member
No. The camaro pump pulley has a different offset from the block. You COULD use that pump if you swap a truck pulley on it.
These accessories are off of an L92 truck, so the upper water pump neck angles a bit differently than the earlier truck pumps.
Turbo diesel
Old 12-18-2013, 12:30 PM   #11
ls1nova71
ls1nova71's Avatar
DBW throttle body will still hit the water neck on the newer truck water pump, so no dice there.
I think the other guy was referring to the gen5 Camaro water pump, in which case you don't need to swap pullies, since the spacing on them is the same as a truck. Just trying to clear things up a bit.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-18-2013, 12:34 PM   #12
ls1nova71
ls1nova71's Avatar
Not true.
This is interesting, do you have any pics of it out of the car? How much belt wrap do you have on the crank?
Old 12-18-2013, 01:47 PM   #13
Wasted Income
Boosted Member
Ahhh, good call. I always assume that people mean 4th gen f-body stuff.
No pics out of the car, but I dug these up...not real clear but gives you an idea. It's not a ton of belt wrap on the crank, but emperical data (tons of highway miles, about 40 1/4 mile passes, countless highway pulls, and a few times on the chassis dyno) proves that it works well. No detectible belt slipping, and the belt has never jumped. I would do it again in an instant.
Turbo diesel
Old 12-19-2013, 04:07 AM   #14
smoky02
I actually ran a 02 GTO water pump and just backed the pulley off a bit with my puller...it's been working great for over 10,000 miles.
Old 12-19-2013, 10:56 AM   #15
Wasted Income
Boosted Member
I don't doubt that. Those pulleys are ON THERE. Such a bish to remove.
Turbo diesel
Old 12-19-2013, 12:41 PM   #16
Custom 68
Custom 68's Avatar
Thanks guys, I had understood the gen 5 camaro pulleys could be used with the truck accessories and the offset was the same as the truck stuff making it an easier swap. I had toyed swaping to a "car" intake but it would only be for looks my truck one is doing just fine.
Dave
