LED King
ABS - not that hard?
This is another one of those pipe dream things but, would it be all that difficult to put ABS on one of these trucks? (other than big $$$) From what I understand, it takes 3 sensors and the control/pump box. I don't know if you would have to change information in the ABS computer like caliper size, weight of the truck, blah, blah. But our '99 Tahoes system seems relitively simple with the electronics and pump in one box plus the sensors. Seems more like a modular system to me. I'm tired of locking up my brakes and would probably do so more WHEN I put on the rear disc brake conversion. (Years down the road).
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
You get what you pay for
![]() Join Date: Dec 1999
I have no idea about ABS. I do know I wouldn't want them if I could. ABS sucks, IMO.
Here's your answer to locking the rears. Worked for me. http://www.73-87.com/garage/lbs.htm
Mike 1985 Chevy C-10 |
i agree, I do not like abs.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
LED King
Can you get a picture of it installed in your truck Mike? I would really aperciate it.
BTW: ABS has saved me in more than one occasion in the Tahoe...
Tyler,
here is a pic of the LBS installed. It is mounted on the passenger side frame rail. ![]() |
Professional Grade
ABS is the most common factor in SUV rollovers. 90% of all rolled Blazers, Tahoes, and Suburbans is due to the driver slamming on the brakes while swerving at the same time, since the brakes don't lock up, they have full steering power, and turn so hard that they roll the vehicle. If they didn't have ABS, then the vehicle would lock up, and not move anywhere slamming into whatever is in the way with a higher chance of occupant survival...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
