Old 07-16-2003, 03:37 PM   #1
mshirey
Question Adding fuse to cig lighter
I want to add an inline fuse to my cig lighter to help protect against frying my fuse box and another cig lighter harness. I'm not sure what amp fuse would be required. 15 amp seems way too low, but I'm not sure if a 20 or 25 amp is the right size. Any suggestions? Has anyone else put a fuse on this circuit? I would like to put some protection on the circuit since the recommended connection in the fuse box is to an unfused connection.
Thanks,
Mike
Mike
67' GMC Fleetside
mshirey is offline   Reply With Quote
Old 07-16-2003, 03:51 PM   #2
oldsub86
A couple of thoughts -
1. fuse based on the size of the wire that you are using
2. fuse low and see what happens - if you keep blowing them, you may need to increase the size from 15 to 20 or 30
3. try using a circuit breaker type like you would use in the setup for a travel trailer harness instead of using a fuse - they are cheap and should reset themselves if you overload temporarily
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 07-16-2003, 04:46 PM   #3
mshirey
I like the circuit breaker idea. Good suggestion. Thanks!
Mike
67' GMC Fleetside
Old 07-16-2003, 06:11 PM   #4
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
If you can find a headlamp circuit breaker, that would be a good size to start. I think they are 30 Amps. You would probably pop 15A if you used the lighter. Pretty much anything else you'd plug in there would work on 15A, with the exception of possibly one of those 3 billion candlepower super duper "No, I ain't spotlightin', Mr. Game Warden" spotlights.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 07-16-2003, 10:01 PM   #5
Class of 69
Class of 69's Avatar
Factory lighter harness had a 30 amp inline fuse. Use 10 gauge wire, no less than 12 for sure!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 07-17-2003, 01:17 PM   #6
mshirey
Sounds like 30a should do it. Thanks for your help!
Mike
67' GMC Fleetside
