Old 12-15-2013, 02:45 AM   #1
BlueJeep
BlueJeep's Avatar
Wider radiator in an AD
Is anyone running a wider radiator in an AD truck, wider than the 22" you can get in a stock core support? I'm building a new core support for mine, and I think I can get a 25" wide radiator in it before the sides of the hood become a problem. Just wondering if anyone else had done similar and if so how did it work out? I'll be running a dual-pass radiator that'll be custom built, so I might as well get as much cooling capacity from it as I can.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-15-2013, 05:07 PM   #2
mr48chev
mr48chev's Avatar
Re: Wider radiator in an AD
I've seen a lot of radiators cobbled into AD trucks after subframe swaps and frame swaps but they usually look like they were indeed cobbled into the trucks It's going to be a bit of a challenge to get one fitted so it looks like it belongs there rather than just stuck in the available space.
My ongoing truck projects:
Old 12-15-2013, 08:25 PM   #3
Henry50
Henry50's Avatar
What engine are you running?
I have a mild 350 with a champion 3 row aluminum radiator, it fits perfect in the truck and runs 165° in the summer.
Henry50 is offline   Reply With Quote
Old 12-16-2013, 10:01 PM   #4
BlueJeep
BlueJeep's Avatar
I'm running a 5.3, but don't have the room for an OEM type radiator because I have an s10 frame with the steering box in the way.
Not all frame swaps are cobbled, plus I'm up to the challenge! Here's one I saw in person this summer, done by the same company that originally built the truck.
Here you can see the lack of a radiator sticking up:
You can see it from the bottom:
And here's the truck I saw it in:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
