Bezel for a Blazer
So I realized long after I purchased this that there is a difference for the K10 and the Blazer. Obviously I'd need to do a dremel mod to make it fit by cutting the line indicated by the arrow.
My question is, does the 70-72 Blazer just have the column at a lower angle/distance? ---
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
Re: Bezel for a Blazer
Weird. I've owned several of these trucks including a Jimmy and a couple Suburbans.
I can't say I've ever seen a low steering column cutout like that.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Roadtrip!
![]() Join Date: Feb 2003
K10 and blazer and all the 1/2 -1 ton trucks use the same bezel. The one you have pictured is for a big truck. C-40- C-60. You can cut it out and make it work.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
The bezel pictured is out oth larger trucks like C40 and larger
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
I agree with the two posts above me. Pickups, burbs, blazers all use the same bezel. You have a bezel for a C40 and larger truck. Cut it out and use it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I'm not at the shop but I'll look when I go back. I know the box it came in has GM stickers with this part number but I want to check the back of the bezel.
Roadtrip!
It is definately a big truck bezel no matter what box it came in. All the 1/2 - 1 ton trucks, blazers and burbs used the same configuration bezel where the cut out would be. Different part numbers would be for 7 hole bezel or 3 hole, choke/no choke, speedwarning hole, gmc would be colored, woodgrain etc but would all still bolt in without any mods. All the C-40-C-60 trucks used the bezel you have pictured
cool, thanks.
also, did the bezels for the c/k10, burbs, blazers, ship with the silver/gray paint as well as the chrome? Thanks for all of your responses, much appreciated!
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- Last edited by dazza; 12-15-2013 at 02:03 PM. |
Gray paint would be a 67/68 bezel, chrome would be 69-72.
Roadtrip!
And to add, some of the later GM bezels came with silver edges instead of chrome for some reason.
