Led headlights
Has anyone installed Harley's Daymaker headlights? They make a 7" light and the only concern would be enough room behind the bezel. I have not test fitted yet. They have a 50,000 bulb life and put out way more light then a halogen or most HIDs. I course the best part is they do not tax the charging system.
I was going to install a set of chrome ones in my truck if it works. |
Re: Led headlights
Another
Re: Led headlights
I wish from a cell you could upload more them one pic at a time
![]() Join Date: Dec 2010
Re: Led headlights
At $400.00 a pop, I don't know.
Old Duffer
![]() Join Date: Mar 2003
Re: Led headlights
They look great as long as you're behind the light, but what about the blinded driver coming towards you?
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
Re: Led headlights
They don't blind oncoming traffic. Are they bright? Sure but not a scattered hid blinding everything light. These are dot lights and really brighten the road. Worth every penny to me.. Not to mention they look cool! I installed tem on my Harley as well as my jeep as they work tht good. Figured next step would be to install them in the c10
Re: Led headlights
I like bright lights but $800 for headlights is pretty steep. I'd like to see what they look like on a truck. Not sure if they will be cool or look like some weird star trek borg thing.
Re: Led headlights
You guys are lookin cheap, I like the lights but I drive a gmc = $1600.00 sounds real high
![]() Join Date: Jun 2012
Re: Led headlights
Not in my truck...
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
Re: Led headlights
I think you can find them on ebay cheaper but still cost more than I want to spend
the H4 conversion works good for me
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Re: Led headlights
Long way till I'm there but I will be doing them without a doubt if they will fit nicely
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Led headlights
I was reading an article recently on LED lights. It brought up a good point.
The stumbling block to LED headlights is that they don't really produce any heat. Therefore, during inclement weather, ice builds up on them whereas on an incandescent, the heat keeps them melted clear.
#13 | |
Re: Led headlights
#14 |
Re: Led headlights
I remember from my years-ago motorcycle work that the aiming point and lens characteristics of automotive vs. motorcycle headlamps were different. I ran a small auto headlamp in a custom (Bates) shell, and it never did 'work' right- kind of useless at night- bad cut-off and dispersion. Conversely, I put a motorcycle halogen headlamp assembly in one of my foglight spots on my old Benz diesel, and it is aimed way too high, and can't be adjusted down any further. I've got some older halogen insert headlamps (7") for the truck- they look like Lucas-style and are automotive. I'm pretty leery of mixing bike and automotive stuff- however, YMMV.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
#15 |
![]() Join Date: Sep 2013
Re: Led headlights
| Bookmarks |
