12-15-2013, 02:43 PM | #1 |
72 EEC gas tank change
I am replacing my 1972 stock EEC gas tank to the non EEC tank. Is there any issues with that? I do not think my emission control people would object (or care). I will check with them first but the main reason I am doing this is to get a way from the charcoal canister and all the tubing that goes with it. Has anyone done this? Is there a benefit to keep it?
Vancouver Bob |
12-15-2013, 11:01 PM | #2 |
Re: 72 EEC gas tank change
You wouldn't have to change the tank. You could just pull everything off. Then cap the vent line on tank and get a vented gas cap.
Only benefit is to Mother Earth!
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). Last edited by airdale94; 12-15-2013 at 11:02 PM. Reason: add |
12-16-2013, 01:35 PM | #3 | |
The Older Generation
Probably wouldn't make a difference to Mother Earth either. I'm betting it hasn't worked for 20 years, unless regular maint. has been performed on it. The charcoal in the canister gets hard after a few years and the whole system is useless... Just my 2¢ worth. LockDoc
