12-15-2013, 03:05 PM | #1 |
91-92 power steering system
I have a friend that has a 91 or 2 4x4 that is junk but the power steering is in good shape, being 4wd and newer I realize that it will be metric but how much other different hurdles would I have to cross to install it on my 67 2wd. Is there a difference in gearboxes, shafts, or bolt patterns?
12-15-2013, 05:12 PM | #2 |
the boat guy
Re: 91-92 power steering system
Lines are easy, use the 91 metric fitting in the back of the 67 power steering box.
73-87 boxes are cheap and easy to find and are bolt on for the 68-72. 67 requires frame modificatio to install correctly.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-15-2013, 05:19 PM | #3 |
OK Thanks Brad I will get on the look out for a 67 gearbox. What kind of frame mods is necessary, are they different bolt pattern or is the frame shaped different right there? Just curious.
12-15-2013, 05:53 PM | #4 |
I am a Referee of life.
67 gearbox will be manual.The PS on the 67 was a ram assist type that connected to the center link.
Use one from about 76 up to get better ratio and bolt on.The frame on a 67 will need to be dimpled for clearance.Whne you test fit you will be able to see where.There'sprobably a pic somewhere if you search.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-15-2013, 06:32 PM | #5 |
Yes, the bolt pattern and type is different. None of the parts he has bolted to his frame will help you steer easier on your truck. If it were that easy I'd have already done my extra 70. The box on the 88-98 Chevy truck bolt on the inside of the frame.
