12-15-2013, 06:43 PM | #1 |
What to save switching to Vintage Air
It will be some time before I purchase the unit but I am going through my parts pile and am wondering if there is anything I may need to keep from my oem air conditioning parts that will be used when I switch over to Vintage Air. I'd like to clean up the garage and need to weed through all my stuff. Tired of tripping over things. Truck is a 67 GMC air cab. Thank you for your knowledge. John
12-15-2013, 09:54 PM | #2 |
Re: What to save switching to Vintage Air
I'm in the process of installing one now. I believe the only thing you use is the A/C dash control, and the side and center vent.
Follow along if you like. Link to my build is my signature below.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
12-15-2013, 10:11 PM | #3 |
Thanks Z10 but after a look at your build I see your truck was a non air cab. There are plenty of different parts included in a air cab that you would not have had. Some of the questions I have are the vacuum controls on the kick vents and vacuum controlled flappers in the cowl area and any other related parts. Maybe should keep everything in case. John
12-15-2013, 10:17 PM | #4 |
I don't think so. You're entire system will come out. The Vintage Air box fits under the dash and is self contained. After you have it mounted and wired, you should only have to run the ducting to your air vents. Wish I mine would have been factory a/c it would have been simpler.
Good luck.
