12-15-2013, 08:14 PM | #1 |
6 to 350 Swap: Will stock 67-72 Ram Horn exhaust manifolds fit an 80's 350?
I'm swapping my 6 for a 350 and I'm wondering if the 67-72 Ram horns a got will fit a GM Crate motor #10066036. I pulled it from a 1981 C10. I skimmed over something on here just mentioning that they don't fit but they didn't elaborate so I'm looking for more info. I know I'll probably need to change the dipstick to the driver's side which is going to be tough since its already in the truck with the oil pan on and I have no idea how to get the stick filler rod or whatever that thing is out or what I'm going to plug the other side up with.
My big thing is the manifolds because I'm on a tight budget and I've already spent a lot of money on this swap so if this doesn't work, then I might just rebuild the 250 and sell the 350 67-72 stuff. I appreciate you input. Thank you. |
12-15-2013, 08:16 PM | #2 |
Re: 6 to 350 Swap: Will stock 67-72 Ram Horn exhaust manifolds fit an 80's 350?
Yes
12-15-2013, 08:18 PM | #3 |
I have rams horn manifolds on my '95 TB FI engine, fit and work great.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
12-15-2013, 11:22 PM | #4 |
That dipstick tube will slide out if you start to wiggle it back and forth for a while. While the manifolds are off you can plug the hole from the hole by silicone [my last option] or rubber plug of some type. Not all that hard. Jim
12-16-2013, 12:15 AM | #5 | |
Thank you everyone for your input. |
12-16-2013, 08:54 AM | #6 |
Watch out for your cornhole !
There's no need to mess with the dipstick. If your new engine has it on the passenger side, just run it. If its on the drivers side, run it. It makes no difference.
