Electrical Problem, turn signal problem
Recently my turn left turn signal has started coming on at random. It fades in and out as if there is a short somewhere. If I turn the left signal on all of my lights blink in sink with the turn signal…..for example my tachometer light….license plate lights, etc. Any ideas?
Re: Electrical Problem, turn signal problem
Bulb may be burnt out or not making a good contact in the socket
oldschoolblazer@yahoo.com
I had a recent prob where I just traced all the wire made sure flasher was in all the way clean up the ground cables turned out I had a pinched wire shorting out.
also check that your emergency flasher button isn't pressed in. good Luck |
Check the bulbs they were good. I'm going to check the flasher and maybe the voltage regulator. Was thinking that the switch in the column for the turn signal could be crossing and causing everything to go crazy.
Ok thanks John, sounds light a good way to start
The Older Generation
Sounds to me like you have a grounding problem. Are all of the stock ground straps in place and making good contact? Here is a thread on ground straps. http://67-72chevytrucks.com/vboard/s....php?p=4200642 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-15-2013 at 10:17 PM. |
#7 | |
Now, if I could just solve the short in my panel lights!! ![]()
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
