Fender mount gas filler
Been looking up past threads for ideas on mounting a gas filler for my under bed mounted 20 gallon Mustang tank. I found a picture of Kid's great truck. His fender mounted gas filler without the usual gas filler door looks GREAT!
Does any one know what filler neck and cap was used? |
![]() Join Date: Jul 2007
Re: Fender mount gas filler
Not exactly sure who's truck you are asking about. There are plenty of options for what you are thinking of though.
photo or link to what you were looking at?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Hollister Road Co.
You will need some bends but the 1TN from Tanks Inc is the neck, TC is the cap and either a GR2 or GR4 for the grommet. I think your 20 gallon tank has the filler to far back to make that work. If it was a 16 or 18 with the filler on top is may work correctly but the 20 is pretty much a back fill only.
http://s308.photobucket.com/user/51g...00144.jpg.html
This is a link to a photo of Kid's pickup showing his fender mounted filler. This is what I want to use on my 48 5 window using a 1969 Mustang 20 gallon tank. I have removed the center fill spout and welded on a side fill neck filler tube. This tank fits perfect. |
#6 | |
Hollister Road Co.
If that's the same truck I'm thinking of, I was under the impression he used the stock filler neck and grommet from the old truck and used elbows etc to make it work.
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
#8 | |
![]() ![]() Join Date: Nov 2008
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#10 | |
Can't help you with the Gray Dan but it sure looks good.
Aah Roger to the rescue. A great tutorial on how to do it.
In case you didn't notice from my pictures, I used the flange that I cut out from the front hole and welded it in the new rear hole.
I cut my patch up front from one my old cab corners that I'm replacing. There's a perfect contour from within the cut-out cab corner. I used my stock filler neck but had to weld a pretty sharp angled extension on it to make the angles right for reaching my tank from the rear fender. |
#13 | |
I like it that you did it so it looks like it could have come that way from the factory just as the gray AD truck was done.
#14 |
very nice work roger55
![]() i so wish i had mounted my gas filler up top of the fender instead of in the middle it looked so natural when i welded it in (sitting a foot off the ground on jack stands)
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#15 |
Some help you'd be, it's light green! ![]() Kid PM'd me with the color name. I'd post it but I don't know if he wants that done or not.
#16 |
My plan is to use one of these. We bought a flat one that I think will work but I really haven't gotten to installing it yet.
http://www.haganauto.com/fuel_doors_gas_lid_s/5.htm Bernie |
#17 |
![]() Join Date: Jun 2011
I cut the fuel door and filler neck from a panel truck and welded it into the rear fender. Worked out really well for me. Not sure what year truck the op is working on.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
