Door sill plates, tail light trim and glove box question!!
So got liner in glove box but could use a few pictures of how steel lip that lock/catch catches on should be mine is bent to hell got it kinda fabed. Also is there something that should push door open? Like spring because i got to pull it open.
Door sills i have look like they should work but how do i mount with lap belt buckle mech in way? Lastly any one know how i could "add" tail light trim if truck doesnt have slots for clips? Would a adheasive work without looking stupid? Or messing up rear fenders in some way?
Project Fast 'n' Loud
72' C10 SWB Fleet, Faux Patina, 383 ci stroker The Page: http://67-72chevytrucks.com/vboard/s...d.php?t=608214 |
#2 | |
Re: Door sill plates, tail light trim and glove box question!!
#3 | |
![]() Join Date: Nov 2012
I think you need some rubber bumpers. You should see some holes on either side of the opening. Wes at Classic Heartbeat sell them, or any number of aftermarket retailers. After that, It's just adjustment of the latching mech. If you have to pull the door open then the latch is adjusted too loosely. Loosen the latch screws, and push it in just a little bit. Try it. If it is the same, push it in a little bit more. eventually you'll have it far enough for the rubber bumpers to do their job.
As for the light, my speculation is that the plug for the fuse box requires you to remove an existing wire, and the second plug is for that wire to plug into. I haven't installed mine yet either, so I'm only speculating. I think for the tail light trim, you need to drill holes. Again, I haven't installed mine yet either, so just a guess. Good luck, Curtis
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
#5 | |
The Older Generation
Do you have the latch striker plate for the lip on the upper dash? As far as the glove box door, yes there is a spring. Read this thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=292857 You can see the ends of the spring in the pictures. It goes all the way through the hinge. LockDoc
#7 | |
Since you have help so much with almost every thread I have had and I appreciate it. Would you be willing to post a pic of striker plate and that upper dash area? Thank you
#8 | |
I am on my way out to the shop now. I will take the camera with me. It may be a little while before I come back in though. LockDoc
Lol. Thats the way it should be and thank you.
Since I had to come in and get a snack & something to drink I will go ahead and post these... ![]() LockDoc
Well thank you. Guess what part I dont have? So add that to the list. Some one must have lost it and just bent the steel down....
They may have pried the glove box open and bent the lip and broke the striker. PM me your address and I will send you one free of charge. LockDoc
