Old 12-16-2013, 01:15 AM   #1
colgad
colgad's Avatar
Best way to paint a bed - apart or assembled
My 67 short fleet is apart and in primer and ready to paint.
Should I paint everything and then assemble.
OR
Assemble and then paint.
OR
Paint base coat assemble and then clear.
As far as I see it I lean toward paint and then assemble but I am sure that I will scrap paint off during the assembly process of the header panel and the rear sill.
What do you think?
What have you guys done in the past?
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 12-16-2013, 01:48 AM   #2
Jahloha
Jahloha's Avatar
Re: Best way to paint a bed - apart or assembled
Not near painting, but thought about this as well. Bump
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-16-2013, 08:51 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you paint it first, you're gonna have to deal with welding afterwards. Remember, the sides are welded in the back.
Old 12-16-2013, 08:57 AM   #4
chiefcfd
chiefcfd's Avatar
I would do both. Trim out the edges that will be hidden, then assemble and paint the entire bed. Remember primer will not protect the metal forever. You will end up with rust under the joints. It will be a lot of work but will be worth it. When you are this close don't rush to the finish line.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 12-16-2013, 09:13 AM   #5
shawno72
C/10 junkie
shawno72's Avatar
Personally if it was primed I would assemble and then paint. Now if you have several buddies who are willing to stand there and hold the sides while you line up holes and stuff bolts then it may not be so bad on re-assembly. I've replaced bedsides by myself on a long bed and it can be tough and not even attempt it painted. Just my opinion but the only piece I would leave separate is the tailgate
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-16-2013, 09:41 AM   #6
colgad
colgad's Avatar
I did not realize that the rear sill is welded! Where is it welded?
Old 12-16-2013, 10:15 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
That's what I did with my stepside bed, it doesn't even have to be body color, just something to protect it (I used black), then assemble, prime, block, repeat paint.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-16-2013, 10:30 AM   #8
68gmsee
Active Member
68gmsee's Avatar
It's easy enough to put together. I've done it twice on my short base but I wasn't worried about scratching or damaging the paint. Also, mine only had welds in the back and I didn't reweld it.
Since it's going to get a paint job anyway, maybe you can just touch up the hidden parts with the paint you're using or get a spray can from a paint supplier. This way you can protect the unseen parts, put it together and then paint without having to worry about nicking, scratching, etc.
Also, keep in mind that if you paint the whole bed and sides while it's apart first then the bolts will not be painted and you will have to do that anyway.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
Last edited by 68gmsee; 12-16-2013 at 11:09 AM. Reason: (corrected. weld was on the rear bedsides)
68gmsee is offline   Reply With Quote
Old 12-16-2013, 01:29 PM   #9
colgad
colgad's Avatar
I looked at another bed I had and saw where it was welded. Thanks for mentioning that.
Since the primer is a 2 part epoxy type it should hold up out of the sun. I am thinking I will just base coat all hidden areas, assemble the bed the same day on a cart, weld/grind/sand/prime the rear sill/bedside area. Base coat everything assembled and clear it. Get friends to put it on the truck and start on the wood.
Still not etched in stone so if anyone has a better way I am still a week away from doing it.
Thanks so much for the input.
Old 12-16-2013, 06:02 PM   #10
68gmsee
Active Member
68gmsee's Avatar
I think you got it... Good luck. Also take pics. We like pictures.
06 Trailblazer
Old 12-16-2013, 08:43 PM   #11
BurlyCrew
Yeah, Jam, assemble, Paint together....
BurlyCrew is offline   Reply With Quote
Old 12-16-2013, 10:38 PM   #12
FirstOwner69
FirstOwner69's Avatar
It's a lot easier to install the wood before placing the bed on the truck.
FirstOwner69 is offline   Reply With Quote
Old 12-16-2013, 11:31 PM   #13
colgad
colgad's Avatar
Good to know, I have done wood on a long bed before but the bed was on the truck and it was a pain. Good to know a better way!!!
Thanks!
Old 12-16-2013, 11:39 PM   #14
colgad
colgad's Avatar
I will take some pic's, I forget with all the work. Ill do better.
Old 03-03-2014, 12:59 AM   #15
colgad
colgad's Avatar
Well I finally got it done, I painted it together. Came out alright, now to install it on the frame.
THANKs AGAIN FOR ALL THE SUGGESTIONS!
http://67-72chevytrucks.com/vboard/p...ictureid=19273
Old 03-03-2014, 08:17 AM   #16
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Wow! That is slick!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-03-2014, 08:26 AM   #17
KEL
72 GMC
KEL's Avatar
Hey Dave
Looks real nice !
KEL
Members I have met :
2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW
KEL is offline   Reply With Quote
Old 03-03-2014, 08:32 AM   #18
2 Far Gone
That's a really good excuse to replace them with polished stainless bolts. It adds detail and finishes everything off nicely.
Mine being a step side, you see most of the bolts holding it together. That was my motivation. Had it been a fleet side I probably would have gone with assembly then paint. Either way, its your truck and your gonna love to drive it anyway.
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=611571
2 Far Gone is offline   Reply With Quote
Old 03-03-2014, 08:41 AM   #19
faribran
Colgate, gotta love that color... Nice job
faribran is offline   Reply With Quote
Old 03-03-2014, 08:41 AM   #20
faribran
Colgad
Old 03-03-2014, 12:03 PM   #21
bruceman1968
bruceman1968's Avatar
Colgad, Looks Great. Just as nice as the cab. You going to have it on by the 16th? Need any help with it? Just holler.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-03-2014, 04:49 PM   #22
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
That does look really nice. Like the color
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 03-03-2014, 08:57 PM   #23
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Good timing on this one, I am almost there. Are the cross members supposed to be painted body color too? I see it looks like you only have the rear one in. That is looking really sharp, nice work. I like the C/50 too.
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
