Best Way to Clean Upper Tailgate Brackets?
Hey All,
I was just wondering what everyone would suggest to clean up a set of the upper tailgate brackets off a 66 Suburban? Mine are a little rusty and kind of stick. Thanks |
Chevy addict
Re: Best Way to Clean Upper Tailgate Brackets?
Get out the steal wool
60-66 Nut
![]() ![]() Join Date: Mar 2007
You might try one of the homemade rust removal brews. They are talked about in the main '60-'66 forum. One of them is a vinegar and water mix. I haven't tried it yet, but it is supposed to work well.
![]() Join Date: Mar 2010
I have always had great results with sandblasting. You end up with a smooth rust free surface.
65 burb On the road Mar 26th Finally |
Thanks guys!
I used lots of WD-40, or Super Tech spray Lube(Walmart version od WD-40), and one of those wire brushes that looks like a toothbrush, and steel wool. Keep them well oiled/lubed as they are irreplaceable!
Thanks 65chevysub!
Hollister, CA.
![]() Join Date: Sep 2006
My hinges are stiff as well .... to the point that they were starting to bent the gate.
So I removed them MONTHS ago, and have been soaking in wd40. I haven't revisited my project in a while, so hopefully they will be freed up by now Worse case, I might have to rehinge or rebush them. Sand/bead blasting is great for surface, but may get hinges gritty
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
