Old 12-16-2013, 03:24 PM   #1
ksshane
ksshane's Avatar
Wheel wells removed - suggestions on securing wiring
My front tires where rubbing my wheel wells so I pulled them. Now Im looking for something a little better than zip ties to secure the wiring harness that goes from the firewall to the headlights etc. on the drivers side.
Any suggestions
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 12-16-2013, 03:33 PM   #2
low&slow
Re: Wheel wells removed - suggestions on securing wiring
Interested in ideas as well. I'm in the same boat. Zip ties aren't really working for me. Truck sits outside and ties break easily when frozen.
low&slow is offline   Reply With Quote
Old 12-16-2013, 07:37 PM   #3
Grumpy old man
Grumpy old man's Avatar
stainless steel zip ties on e bay
Grumpy old man is offline   Reply With Quote
Old 12-16-2013, 07:42 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
This is what I would use. Available at most auto parts stores. Attach to existing holes in fender.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 12-16-2013, 08:30 PM   #5
sduckworth13
sduckworth13's Avatar
Here is a link I found with some wiring loom clips.
http://www.clipsandfasteners.com/Cli...uting_s/79.htm
Scott
sduckworth13 is offline   Reply With Quote
Old 12-16-2013, 10:12 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: Wheel wells removed - suggestions on securing wiring
I know it's your truck but I would be more concerned with what the tires are going to be throwing up into the hood and bouncing all over the motor and everything else!
Just saying.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-17-2013, 12:53 AM   #7
cool68
completely removing wheel wells not a solution to problem with tire rubbing. modify wheel well, or buy custom aftermarket ones. even partial wheel well will help keep debris, water, etc out of engine bay. plus, helps support the fender/hood.
cool68 is offline   Reply With Quote
Old 12-17-2013, 10:55 PM   #8
CG
BlahBlahBlah
I have an off topic truck (but its way cool lol) and I drove it a bit without the wheel wells, and never in the rain. Man did it make a dirty mess in the engine compartment. So like has been said, do what you can to get the wheel wells back in there.
In the mean time those clamps with the rubber on them someone posted up are pretty inexpensive and work great. You can also get some of that wiring cover ... its plastic with a slit in it so you can tuck your wiring in there. Sorry dont know what its called, but it works real slick.
Old 12-18-2013, 11:09 AM   #9
ksshane
ksshane's Avatar
Oh I wont be leaving the wheel wells out. My front end just decided to settle into place about 30 miles from my home and this was the quickest way to get back on the road and get her home.
I will be making or buying some wheel wells next year that will clear. Just needed some ideas to get me by for now. The clamps look like the way to go until I can replace the wheel wells.
Old 12-19-2013, 01:15 AM   #10
trf63
trf63's Avatar
http://www.magdaddyusa.com/
superstrong magnets with clips
trf63 is offline   Reply With Quote
Old 12-19-2013, 10:43 AM   #11
Fatherflash
Fatherflash's Avatar
We use these all the time at work and they do the job. The wiring bundle stand offs that get wiring off decks, away from frames to prevent rubbing are really nice.
http://www.clickbond.com/modules.php...&categoryid=89
If you go this route, ensure you follow surface prep requirements or else they will pop.
My other vehicle is unmanned....
Fatherflash is offline   Reply With Quote
Old 12-19-2013, 11:12 AM   #12
ksshane
ksshane's Avatar
Ah... click bonds. Used those for almost 13 years when I worked in aircraft.
