12-16-2013, 08:05 PM | #1 |
Loose handles- What to do
My door and window handles keep coming loose and sometime will fall off when the door is closed. I know that I could use thread locker on the screws but I was wondering if anyone come up with a better way of attaching the handles. I was thinking of drilling and taping into the end of posts then running a screw thrugh the handle into the post. What do you guys think?
12-16-2013, 08:21 PM | #2 |
Re: Loose handles- What to do
I put good quality set screws in mine with the thread locker for small screws. That way I can get them out later.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-17-2013, 12:27 AM | #3 |
Make sure your handles are still good enough to grab onto the post. If they wear out the screw can come loose. New handles are cheap enough to replace.
66 shorty |
12-17-2013, 12:41 AM | #4 |
+2 check the inner splines and if worn, get some new handles. Same thing happened on my Burb. Replaced the handles and no issues.
GOD BLESS AMERICA! |
12-17-2013, 10:39 AM | #5 |
Are your handles OEM or reproduced? I've heard a lot of guys who have the same issue w/reproduction handles.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-17-2013, 10:47 AM | #6 |
12-17-2013, 10:58 AM | #7 |
Classic Parts of America has them. This is a foam style washer that goes behind the door panel over the spline, and a plastic washer that goes between the outer panel and the handles.
I had the same issue w/a repop handle and put just a small piece of Teflon tape on the threads and it quit backing out. I went back to OEM handles since then.
12-17-2013, 11:17 AM | #8 |
Use 2 (shorter, if needed) set screws, one jamb'd onto other.
Sam |
12-17-2013, 11:18 AM | #9 |
That sounds like a good idea also...
12-17-2013, 12:46 PM | #10 |
12-17-2013, 01:39 PM | #11 |
meowMEOWmeowMEOW
Take a little jb weld or epoxy, and line the splines on the shaft with some vaseline or release agent. Fill the handle cup with the epoxy and slip it on, allow to harden, and remove. It creates a cast with new splines. Clean out the set screw hole, and then go back to using it as normal.
12-17-2013, 02:58 PM | #12 |
I see them on ebay quite a bit and I believe Tim Tygerts at Obsolete chevy parts may have NOS on the shelf. You can always get some used ones and have them replated too.
