Old 12-16-2013, 09:15 PM   #1
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
Glad to be back
I am finally on shore duty and have the time to pick up the hobby again. I recently purchased a 1966 GMC step side.
First question. I attached some pics of the dash. The amp gauge looks original, and i know the temp gauge to the far left isn't. What usually goes there?
Thanks again.
perrosinpata@aol.com is offline   Reply With Quote
Old 12-16-2013, 09:41 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Glad to be back
Clock on the right, Tach or Bat-O-Meter on the left.
Old 12-17-2013, 10:10 AM   #3
1963c-10
1963c-10's Avatar
Re: Glad to be back
Welcome back and thanks for your service. Great looking truck and we'll want more pics of the progress and some updates on the build.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-17-2013, 04:06 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Re: Glad to be back
Welcome back and thanks for your service! Nice truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-17-2013, 07:56 PM   #5
Re: Glad to be back
Great to be here Proud to Serve!!
I didn't waste anytime.
1. Replace the starter 49.00
2. I changed the points distributor to an HEI. She cranks over with spark, but when I turn ignition to off engine keeps cranking sometimes. Possible ignitions switch? or It has an alternator with an internal regulator. The original voltage regulator is plugged in and still wired, can it continue to supply power?
Old 12-17-2013, 08:13 PM   #6
RANDY COX
RANDY COX's Avatar
Re: Glad to be back
sounds like you have your timing off.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-18-2013, 10:22 AM   #7
Re: Glad to be back
Verified timing and its correct 18436572.
The engine continues to turn over even when the ignition key is off.
Old 12-18-2013, 10:33 AM   #8
Ta2Don
Ta2Don's Avatar
Re: Glad to be back
Thank You for your service!!!
Firing order looks right, so that begs the question, have you hooked up a timing light to check it? Just asking because your post mentions the firing order but not the degree of timing… i.e. 4 degrees BTDC
I had a similar issue with a 283 many many moons ago and the distributor had slipped due to a loose clamp bolt...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-18-2013, 10:50 AM   #9
Re: Glad to be back
Thanks for the quick response. I will try that today.
Old 12-18-2013, 10:57 AM   #10
jchav62
1962 C-10
jchav62's Avatar
Re: Glad to be back
Nice project! That's an aftermarket amps gauge. Those spaces are usually blanks on most pickups...reserved for a tach on one side, air gauge on the other...usually found in big trucks.
As for the running after off issue... is it "dieseling" or running normal?
I've heard of issues where the altenator or generator causes something to make the engine keeping running in the off position..
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-18-2013, 11:24 AM   #11
Re: Glad to be back
Thanks for the reply. The engine continues to turn over. The starter stays engaged.
Old 12-18-2013, 11:36 AM   #12
jchav62
1962 C-10
jchav62's Avatar
Re: Glad to be back
The starter may need to be shimmed... also, check to make sure the switch is good.
Joseph Chavez
Old 12-18-2013, 03:05 PM   #13
jtrichard
Re: Glad to be back
the still cranking problem can be in the starter solenoid or it is getting power to the solenoid it could be some kind of back feed or the ing. switch..... both the left temp and the amp gauges are ad-dons.... org.amp and oil was/is idiot lights in the upper holes on each side of speedo
jtrichard is offline   Reply With Quote
Old 12-18-2013, 08:21 PM   #14
Re: Glad to be back
Thank you for all your help. I took advantage of the nice weather today.
I tried again today and started to smell like rotten eggs so I stopped cranking.
Instead I removed the edelbrock 1406 carb and cleaned it out. I found a sticking needle on one side and dirty jets.
Old 12-18-2013, 11:37 PM   #15
Re: Glad to be back
How do you tell if your alternator is internally regulated?
Old 12-19-2013, 11:48 AM   #16
jchav62
1962 C-10
jchav62's Avatar
Re: Glad to be back
The easiest way to tell is by the connection. The interally regulated alt has a flat plug... the external more square shaped.
Joseph Chavez
Old 12-19-2013, 11:51 AM   #17
jchav62
1962 C-10
jchav62's Avatar
Re: Glad to be back
Internal on left.. external on right.
Joseph Chavez
Old 12-19-2013, 12:04 PM   #18
Re: Glad to be back
Well looks like I have an external regulator. Thanks for the quick reply.
Old 12-19-2013, 12:50 PM   #19
1963c-10
1963c-10's Avatar
Re: Glad to be back
You'll find it next to the horn relay on the driver side of the core support. 3 bolts and a plug....5min job to swap. Be sure to unhook the battery and install the ground 1st prior to hooking up the positive. I learned the hard way twice a few years back when I kept frying them new out of the box.
Old 12-19-2013, 12:54 PM   #20
padresag
Re: Glad to be back
when you install a hei are you not supposed to remove the wire from the starter to the distributor. that was the 12 volt wire for the extra juice when starting. the wire from the ign switch to the coil was 9 volts(resistor wire) that should be removed and a non resisted wire installed so that there is 12 volts all of the time. sounds that the wire is still there and you have it hooked up so that it is hot to the starter somehow and is keeping the starter engaged??? remove that wire.
ron
padresag is offline   Reply With Quote
Old 12-19-2013, 06:30 PM   #21
Re: Glad to be back
I disconnected the purple wire (S terminal) going to the cab and went straight to the battery.
The positive battery terminal gets super hot. The starter solenoid is either getting stuck or its back feeding.
Old 12-19-2013, 08:22 PM   #22
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: Glad to be back
Is the original voltage regulator still wired for the original external alternator?
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 12-20-2013, 02:41 PM   #23
kieth
kieth's Avatar
Re: Glad to be back
Thanks again.
HERE'S WHAT WE DID WITH MY 66 GMC INSTRUMENT CLUSTER:
http://kieth.smugmug.com/Trucks/66-GMC/i-X8WmmMg
WE GMC GUYS HAVE TO STICK TOGETHER
kieth is offline   Reply With Quote
Old 12-21-2013, 08:06 PM   #24
Re: Glad to be back
Are the tach and vacuum gauges the originals?
Looks like the starter solenoid was sticking keeping the starter engaged. I charged the battery and it fired up.
