deluxe trim
I'm installing deluxe fender trim on my 70'. Does anyone have any tricks to drilling the holes for the clips in the correct place?
Thanks, |
![]() Join Date: Oct 2009
Re: deluxe trim
this might be helpful vova -
Moderator
![]() Join Date: May 2007
Re: deluxe trim
I used the factory assembly manual for the locations. Use a step bit to drill the holes.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#4 | |
Re: deluxe trim
#5 | |
Re: deluxe trim
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Re: deluxe trim
I've seen that on a few trucks (didn't notice it in this vid) so I think it is a common mistake. Whatever you do - make sure to get measurements from a known original truck or from a member or from the assembly manual (best source).
Re: deluxe trim
Here is an old thread with scans from the GM assembly manual, showing the hole locations for the trim:
http://67-72chevytrucks.com/vboard/s....php?p=1971021 Hope this helps.
1971 C10 Longbed, 350/TH350 |
Re: deluxe trim
Which trim follows the wheel wells? Is that OE or aftermarket? I think Ive only seen it on 67/68s.
Similar to this although Ive seen a better one on this forum that is solid, doesnt have the split in the center. ![]() |
