Fuel Pump ???
I just got a new fuel pump, but it only has 2 ports while my current pump has 3. I know that the "extra" line is a return. is the return line necessary on a 72? or can I run the new pump without the return with no issues??
Re: Fuel Pump ???
I just did this to mine. Installed a 2 port fuel pump and just left the one coming from the tank unhooked. No problems. Many people do this
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
Re: Fuel Pump ???
I didn't think it would be a problem. but I wasn't completely sure! thanks
Re: Fuel Pump ???
What pressure does the carb need and how much pressure/flow does the pump produce? If it is a high pressure/volume pump you should run a return line. If not I believe the pump won't last as long. Don't know all the details but I remember that from when I installed my blazer tank (and used the in tank pump).
Re: Fuel Pump ???
it is a high pressure pump. I do have an adjustable pressure regulator set at 6 psi.
Parts and more parts
Re: Fuel Pump ???
What brand of fuel pump did you purchase? I put an Edelbrock fuel pump on my 84 and it only had the two ports, where the factory installed one had three. I found that I had some issues with the fuel line getting vapor locked, so I purchased the Edelbrock lower plate that has four ports in it and made a small outlet for the return line. This solved some of my overheating of the fuel and allowed for me to run a high pressure pump without issue.
Frank |
Re: Fuel Pump ???
I also have the high pressure edelbrock. where did you get the plate??
Re: Fuel Pump ???
part number out of Edelbrock on-line catalog and ordered from Summit Racing
Frank |
