Old 12-17-2013, 01:42 AM   #1
Jahloha
Jahloha's Avatar
How Do You Prep Inside Frame Holes
TEAM:
I have prepped the front end of my frame for primer, but do not feel the edges of all the holes in the frame are paint ready.
Name:  After Wire Brush.jpg
How do you normally address these holes in preparation?
Should I just roll some sand paper and use a finger?
Mahalo!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-17-2013, 03:37 AM   #2
rich67
rich67's Avatar
Re: How Do You Prep Inside Frame Holes
te smaller ones you mite run a correct size drill bit thru first. they make small flapper wheels for your drill too. or glue a piece of sand paper to a wood dowel. just some ideas.
rich67 is offline   Reply With Quote
Old 12-17-2013, 11:21 AM   #3
Jahloha
Jahloha's Avatar
Good idea on the drill bits, I will just be careful to not elongate. Was trying to find cone shaped wire wheels, but couldn't find something like that for the holes.
Anyone ever see something cone shape for wire wheels?
-JASON
Old 12-17-2013, 12:40 PM   #4
Carl Spangler
Carl Spangler's Avatar
If you have a dremel tool, this little 1/2" brush might be a solution:
http://www.amazon.com/Dremel-442-Carbon-Steel-Brus... http://www.amazon.com/Dremel-442-Carbon-Steel-Brus...
Carl Spangler is offline   Reply With Quote
Old 12-17-2013, 12:50 PM   #5
BurlyCrew
A wire battery post & terminal cleaner tool works good too....
BurlyCrew is offline   Reply With Quote
Old 12-17-2013, 12:53 PM   #6
Jahloha
Jahloha's Avatar
http://www.amazon.com/Dremel-442-Car...2+dremel+brush
Dremel is another tool on my list to buy soon haha.
Great idea. Have one laying around, just didn't event think about it.
-JASON
Old 12-17-2013, 06:42 PM   #7
Unionwelder
Unionwelder's Avatar
Any welding supply house will have coned wirewheels
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 12-17-2013, 06:44 PM   #8
Jahloha
Jahloha's Avatar
Unfamiliar with welding supply houses. What are some names of such suppliers? If there are nation wide options.
-JASON
Old 12-17-2013, 07:16 PM   #9
Carl Spangler
Welding supply online stores..................... way too easy to spend 'fat stacks' on welding equipment.
Ask me how I know...............
cheers
JohnG
