12-17-2013, 10:38 AM | #1 |
Factory Carb Size
Anyone know the factory carb size on an 86 Chevy dually with a BBC 454? Im pretty sure its a 750 but im debating on new airgap intake and carb since the edelbrock on it needs rebuilt anyway. Here is what I was thinking or should i just go back to a summit quadrajunk so all my stock stuff will still fit since all my vacuum lines are still hooked up and only thing not hooked up af far as i can tell is the overflow from the carb to the charcoal canister.
http://www.summitracing.com/parts/cmb-03-0224/overview/
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
12-17-2013, 11:08 AM | #2 |
Re: Factory Carb Size
I checked my factory information and while it lists carburetor type, venturi size and choke controls it does not specify a cfm rating.
K http://www.gmheritagecenter.com/docs...olet-Truck.pdf
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-17-2013, 11:23 AM | #3 |
I just wonder if maybe a 750 is a bit overkill for an 80s stock 454??
12-17-2013, 11:44 AM | #4 |
750 is what I'm planning on using for my "much big than stock" 454. In my opinion 750 is a little to big for stock.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
12-17-2013, 11:55 AM | #5 |
Isn't it an 800cfm q-jet from the factory?
As for after market what I use is 600 up to 325hp or so and 650cfm (thunder) up to 400. Anything in the 400hp range I use a 750. I've never had anything over that so don't know where you'd want an 850 or 1050. |
12-17-2013, 12:18 PM | #6 |
I do pretty much the same thing thats why it baffled me when all i seen was 750's when i put in my truck info on summit. Love the intake and carb combo but 750 i think is a bit of a stretch.
12-17-2013, 12:22 PM | #7 |
Well, remember, it's usually just a 2-barrel for the average joe.....unless you drive like my wife. Then turns into an industrial water hose.
12-17-2013, 02:41 PM | #8 |
Mines the complete opposite she drives like shes on thorazine unless shes headed out of town on vacation then she puts new meaning to drive it like ya stole it.
12-17-2013, 08:10 PM | #9 | |
The Q-Jet's secondary air doors only open as far as needed to meet the engine's airflow demands. Combined with their relatively small primary venturis, that allows a 750 CFM Q-Jet to be used in applications where most other types of 750 CFM carbs would be too large and suffer from driveability issues. |
12-17-2013, 10:07 PM | #10 | |
12-18-2013, 06:05 AM | #11 | |
I believe mine is an 800 cfm.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
12-19-2013, 10:49 AM | #12 |
I finally decided to just stick with the edelbrock thats on there. Pretty sure its a 600 but I will know for sure when i rebuild it. Truck sat up for a number of years so its dumping fuel into the primaries. I also bought me a decent K&N 6" tell air cleaner and a few other goodies while i was at it so hopefull shell be running tip top shortly.
