![]() Join Date: Jul 2012
Re: carpet?
+1
![]() Join Date: Sep 2013
Re: carpet?
Just received my carpet from Stock Interiors. Kinda wondering the same thing?
72 Chevrolet SWB Super |
![]() Join Date: Sep 2011
Re: carpet?
Using a hair drier to warm them up will help keep them from cracking, just warm up the lower as you wiggle and pull up. But the next part is a treat on the drivers side, If you still have the in-cab tank access to the retractor bolt is a B**** ! If you get it out your good to go....................................or just slit the carpet and tuck.....all done!
1967 C10 SWB Owner - Rustbelt Restorations |
Re: carpet?
You shouldn't have to do any cutting. Those plastic pieces should move enough that you can get to the bolt to remove the whole thing. If they are original seat belts, it's probably a good idea to replace them too.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#6 | |
Re: carpet?
#7 | |
Re: carpet?
Re: carpet?
Do it when it is warm or inside , hair dryer on bottom of cover works well, bolt removes from top , not bottom ? Go slow or the plastic will break, do not pry up from below On cover ! It will break from age of plastic . If you are not anal about date coded belts, get them rewebbed with new fabric before you reinstall them. Just my opinion.
71 C-20 07 Magnum RT AWD |
#10 | |
Re: carpet?
